if this is an older tv and your state might have changed to digital programming then i would suggest trying to look at the back of the set and see if you have anything to fix this problem or you might want to CHECK AND SEE IF YOU HAVE VIDEO ON or CABLE on or TV on. Sometimes if you have Antenna switch to cable then your channels would be red and picture distorted. change the antenna to air for tv. or from tv to cable.
This sounds Like the the coolant for your piture tube has become cloudy and needs replacement (usually blue or green tube - thats why the image seems ovrely red).It's a big job (labour wise) since completee dissassembly is required ($200-300). It can be done youreself - check out TVrepairkits.com to get the coolant and instructions.
You can confirm that this is the problem by dissassembling the unit to the point where you can view the face of the CRT's (red green and blue) directly.
Make sure if your using the video input jacks, that the yellow is plugged into Video 1 and the same with the audio.Red & White. If your using Component, they are color coded- Red Blue & Green along with the Audio In -Red & White. It sounds like you have the video in the wrong jack.
hi..It's probably a loose cable. The first one to check is the
green connection but make sure they're all tight. RCA cables
tend to pop out part way which is enough to stop the signal.
If the green signal is lost, you get no picture. If the red or blue
are lost, you get a picture with bad coloring.
If you still have the problem check this
LOOK in the back of the TV when you have it turned on. Look in the slots near the top for a white glow coming out of it.
IF you see it, you need your signal board replaced...
IF NOT, then you need your power supply board replaced...
BLACK and RED are 110-120VAC each. WHITE is NEUTRAL - does not carry power. GREEN is GROUND. The Black, Red, and White Wires should connect to the terminal block & should correspond the colored wires already connected to the block from the machine. The Green wire should be grounded to the equipment chassis. I hope this answers your question.
do you happen to have any speakers of any size within about 3 feet in any direction of the tv??
move them if so,
I have large speakers about 5 feet from my tv at home and i still get some distortion once in a while with red and dark green streaks.
I had a problem with my TV colors not lining up. One day I turned it on and the green was out of wack. I checked this message board and replaced the STK chips, bad soldering and all led to me just giving up on that and buying a whole new Convergence Board ($185). I just plugged this in and though now my Green lines up okay, my red is out of whack. Is there something I am doing wrong?
Can anyone help me? Did i miss a step? Frustrated......Bruce
You might have "color filter" settings. Turn the digital filters off. Here is what manual at p72 says.
"You can take pictures using digital filters. The filters consist of color filters such as red, blue and green, a soft filter that produces a fuzzy effect. Color filters Eight colors, black-and-white, sepia, red, pink, violet, blue, green and yellow, are provided for the color filters. When you select a color filter in the Digital Filter mode, the display on the LCD monitor is filtered with the selected color, and the pictures are taken in that color."
