My Keurig makes a perfect cup but then fails part way thru drawing in water for the next cup. Add water light comes on even though reservior has plenty of water??
SOURCE: The add water light stays on not matter how much water is in the reservoir
lot of time you have a magnet in the water tank fill it with water and gently tap the side of machine the magnet is block or jam on empty
THANKS FOR USING FIXYA
PIERRE
SOURCE: Keurig Model B50 "add water"
The level switch is probably bad. If you need repairs, contact [email protected]
SOURCE: Keurig will work only part time. Sometime will
The water reservoir tank probably isn't seated properly. Try wiggling the tank a bit and if that doesn't do the trick, completely remove the water reservoir and then replace it. Once it's seated properly, it should start drawing water and brew as designed. This seems to be a design flaw with this particular model, so periodic adjusting of the water reservoir may be necessary to ensure it is seated properly if your problem persists. Hope that helps! Best of luck...
SOURCE: Water runs continuously and doesn't
Hi, According to you the water is not heating of your coffee maker. There is some problem with the heater system of coffee maker. May be the fuse is dead or the connection or the wiring cut out. check ant repair it. May the brewer need cleaning. Periodic descaling of the machine is recommended for your brewer. More frequent descaling may be necessary depending on the hardness of the water. See the manual or contact with nearest service center.
SOURCE: Keurig B40 Elite; once turned on can hear the pump
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
