SOURCE: Bosch Classix 1200 washing machine
check the water in let valve connections and the current over it when it is in the fab cond. cycle. Replace valve if current is on. Valve price range is 15-35$
SOURCE: Conditioner drawer not emptying out
hiya
more than likely the cold inlet valve as mentioned above, these are not hard to replace so even with minimal diy skills should be an easy fix. i think £30 is a bit steep for one of those though even if it is a genuine bosch part. try these as i've always found their prices quite cheap
www.masterpart.com
Phone Sales on 0871 811 7011
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
SOURCE: Only adds water and drains
I can think of a few things to try.
1) Check for a blockage in any of the pipes or if it has one the filter
2) Brushes might be worn on the motor
3)A faulty module. The only way to check this last one is to replace with a known working one.
Good luck.
SOURCE: drum not working on bosch washing machine
I would say that the brushes want replacing in the motor, access to the motor is by removing the rear panel, remove the belt, and undo screws securing motor, remove motor, brushes are located at rear end of motor.
Please rate my solution.
Thanks
SOURCE: my bosch classix 1200 fl wont spin or drain
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Plug
off the wall first. Remove the front
lower panel, screws underneath. Be
prepared for water, drain out from drain hose.
Check filter for clogging, clean out.
Sometimes when the load is unbalanced & the machine cannot adjust
the load it stops. To avoid this make
sure your wash is mixed with big and small clothes.
If
this does not work remove the rear panel & check belt, should have half
inch ‘give’. Still not good, remove belt,
unscrew 2 bolts that hold the motor, unplug the motor connector, lever the
motor back with a screwdriver. Check the
motor brushes (at terminal end of motor), if they are any shorter than 1 cm
replace brushes.
Try
these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
