What is a cartridge puller?
SOURCE: using a moen cartridge puller and still cant get
Haave you removed the U clip? It slides down from the top of the valve body. They can be hard to remove but will come out.
SOURCE: No pressure.. Help
cartridge # 1222,i am not aware of the # for the puller, i just asked for a moen puller.be sure to get one that pull's pos'i cartridge's. because the older type puller will not pull positemp easy.and while you have cart out run water to flush valve body out.good luck!
Testimonial: "Thanks Guy , I figured it out over a month ago , you're right replaceing the cartridge did the trick . Moen will send you the cartridge free. "
