Dometic 3109228.001 Duo Therm Comfort Control 5 Button Logo
A
Anonymous Posted on Aug 09, 2014
Error code E2
What does the error code E2 mean?
william simpson
Level 3:
Genius:
  • Dometic Master 1,363 Answers
  • Posted on Aug 16, 2015
william simpson
Dometic Master
Level 3:
Genius:
Answers
1363
Questions
14
Helped
318031
Points
1636
Open circuit or out of range indoor temperture sensor. locks out cool and heat.
2 Related Answers
hvac1960
R Subramaniyam Iyer
  • 2133 Answers
  • Posted on Jan 01, 2011
SOURCE: Dometic B-1901 Error code
Indoor coil temp sensor defective. Replace it.
Anonymous
  • Posted on Jul 15, 2011
SOURCE: The thermostat is flashing and E2 error
It means the trailer is too warm for the thermostat to work - above 90 degrees inside. Take some ice and put in ziplock bag - place over thermostat and cool it down. Unit will start working when thermostat senses it is BELOW 90 degrees. FAULTY DESIGN.
Haam washing machine error e2
Never heard of the make 'Haam"? Perhaps you mean 'Haier'? Anyway, it might be a generic drain error
An E2 Error code indicates that the washer is still draining after 8 minutes. Check the following: Check that the drain hose is not more than 391 ?3" (100 cm) from the floor. Remove any clogs from the drain hose.
E2 - Error Code - Stacked Laundry Center - Product Help
What does the code E2 mean in a Kenmore Elite washing machine mean
Hi Ryan, an E2 error code is a stuck button on the control panel. Try pressing the buttons slightly off center to see if they free up, if that doesn't clear the error code then the control panel needs to be replaced. Hope that helps.
1helpful
What does E2 -F 1- mean?
A E1-F1 or E1-F2 is a faulty touchpad.
FixYourBoard.com has replacements about for NLA ovens.
They come with a two year warranty.
Reach out to us at 512-355-1108 or [email protected]
What does E2 mean?
Error Codes mean different things on different machine brands. It is an error message indicating your machine is malfunctioning. Usually your owner's manual will have a list of error codes in the Troubleshooting Section that describes the problem and suggested resolution. If not, then search the internet for your machine's:
Manufacturer + Model + error code E2
Kettle does not heat. What does the E2 message mean
SMEG DISHWASHER ERROR CODE E2? - How To Mend It
howtomendit.com > Kitchen Appliances, Electric Kettles
Free repair help - smeg dishwasher error code e2. ... Q & As - mend, repair, fix kitchen appliances, electric kettles, kettles, water, not, plug ... Search for - error, e2 ...
Kelvinator beverage cooler E2 error code
Temperature sensor error code.
Login'Contact Us Appliance Appliance Repair Questions? Ask a Technician for Answers ASAP
Ask an Expert Home Improvement Questions Appliance Technician
How JustAnswer Works:
  • Ask an Expert
  • Get a Professional Answer
  • 100% Satisfaction Guarantee
Ask Daniel Your Own Question
Daniel, Home Appliance Technician
Category: Appliance
Satisfied Customers: 16124
Experience: 20+ yrs. experience in white goods repair. NVQ Level 2 electronics manufacturers training courses. Type Your Appliance Question Here... Daniel is online now Hi, I have a BWE40 Wine Cooler and an E2 Error Message.
Resolved Question:
Hi, I have a BWE40 Wine Cooler and an E2 Error Message. What does this mean please?
Submitted: 3 years ago.
Category: Appliance Share this conversation
Expert: Daniel replied 3 years ago.
Hi
E2 error code is a temperature sensor error code.
Remove the plastic black cover on the back and you will see the control board.
On the board you will see a wiring block with 4 thin wires going to it.
Test the 2 wires on the left and the 2 wires on the right with a multi meter. The reading in Kohms (kiloohms) should be the same.
If any are faulty then they will need to be replaced.
If the readings are the same, replace a faulty control board to be rid of the E2 error and your problem.
2helpful
2answers
My washing machine toshiba aw-9760s Kept showing this "E2 -3" problem. Whenever i close the lid to start washing my cloths. Anyone here can help me? In need of answers A.S.A.P
I also have a Toshiba AW-9790S, and encountered similar problem. The E2-3 would occur sporadically and halt the washing programme. E2-3 error occurs when the washing machine detects that the lid is not properly seated and locked during the rinse or spin cycles. I took mine apart and resolved my problem by cleaning the contacts for the switches. There are 2 contact switches at the lower right side; 1 for sensing the lid is closed and 1 for sensing that the lid lock is engaged. Both the switches were slightly oxidized which prevented current flow and the sensors from working properly.
2answers
What does an E2 code mean? I have a Haier Dehumidifier that is about a year old, I emtied the bucket and put the bucket back into place and hit the start button and nothing happen I unplugged the unit and...
I have a Haier Dehumidifier that is about a year old, I emtied the bucket and put the bucket back into place and hit the start button and nothing happen I unplugged the unit and error code E2 keeps comming on
Top Dometic Heating & Cooling Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
