Arris SURFboard® SB5101 Cable Modem Logo
A
Anonymous Posted on Aug 09, 2014
How do i disable ap isolation on a motorola surfboard?
I need to connect Chromecast an it gets through the setup and tells me it's ready to cast, but its not showing up on any of my devices.
  • Official Brand Answer 3,100 Answers
  • Posted on Aug 10, 2014
Motorola Mobility
Level 0:
Answers
3100
Questions
Helped
684194
Points
13487
Contact Arris.
ARRIS
Mark
Motorola Support
4 Related Answers
Anonymous
  • Posted on Feb 03, 2009
SOURCE: Motorola SB4200 IP address
192.168.100.1 this is the default IP adress
Anonymous
  • 2992 Answers
  • Posted on Mar 11, 2009
SOURCE: need instalation help (no disk) for surfboard sb4100
The download page for these products at Motorola's site is here. If you don't trust clicking a link, here's the URL:
http://broadband.motorola.com/consumers/support/default.asp?supportSection=DiscontinuedProducts
The SB4100 is about midway down the page. All the drivers and documentation is listed there. Just click on the link for whatever you need.
Please take a moment to rate this solution a fixya if it's been what you need, and thanks for asking here!
Anonymous
  • Posted on Apr 25, 2009
SOURCE: Motorola surfboard sb5101 only gives me a
if you use the usb cable can only be sure your connection is 12Mbps, try to use lan cable that you certainly can. I also use the usb only 12Mbps, but can I use lan cable I can be more than that
nyilasrobert
Robert Nyilas
  • 627 Answers
  • Posted on Jul 24, 2009
SOURCE: problem connecting acer aspire 4736, motorola surfboard sb5101
2ways:
go to the msi website and use the live update
or you can get drivers from here
4answers
Can u cast movies from ur phone to this TV and if so how do u set it up
if your tv have mirroring... To set up screen mirroring on your Smart TV, press the Input button, and choose Screen Mirroring on the display of your TV. An HDTV is not not normally set up for screenmirroring out of the box. You will need an AllShare Cast Wireless Hub as a bridge to connect your HDTV to yourphone.
1helpful
2answers
How do I reset my chromecast audio?
  1. Connect your Chromecast Audio to the speaker with one of the three supported audio cables.
  2. Step 2: Power on the Chromecast Audio. ...
  3. Step 3: Hold down the only button next to USB port on Chromecast Audio.
  4. ..
  5. . chromecast setup ' chromecast com setup ' chrome cast com setup
I have not been able to use a chromecast with my tablet
you need to setup chromecast on a pc. and connect through the wifi to to the cast. setup the cast for your wifi and i.e it will ask for the wifi code or the sink to be activated. then any device connected to your wifi will work the cast. you do need a google account to log the cast. your device will need the chrome cast app installed for it to work as well
2answers
How do I connect my router N600 to Chromecast?
  1. Check your NETGEAR router settings
  2. Uncheck Enable Wireless Isolation This step will disable AP Isolation.
  3. Uncheck Disable IGMP Proxying This step will turn Multicasting ON.
Chromecast not working
Is the chrome cast setup correctly? If yes, then make sure they're in the same wifi network. Other wise you can try unplug and plug chrome cast and reboot the wifi to see if that fixes it.
2answers
Disable ap/client isolation to allow chromecast to work
You need to login to the routers web interface and the settings will be in the advance WiFi section, probably a tick box.
A typical web interface can be found at the following address in your browser http://192.168.1.1/
Username usually admin and password could be password or blank or 1234 or admin. Check with manual.
Connect chromecast to belkin wi-fi
Ensure that wireless isolation (or any labeled form of network isolation) is disabled, though it shouldn't be enabled unless it was manually set that way. I've also run into this issue when setting up Chromecasts occasionally, and I had to do a factory reset (hold down the small reset button on the Chromecast for 30 seconds) and repeat the setup process in order for it to be detected. You might try that as well.
Top Arris Computers & Internet Experts
Jesse Walters
Jesse Walters
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
