Why won't engine start in "on" position. Spark plug was replaced. Can't find choke, not sure if it has one.
SOURCE: Katcher pressure washer w/ 5hp Honda Engine
pour a bottle of carburettor or fuel injector cleaner in the fuel tank, replace the spark plug and set the spark pluglug gap at 0.7mm. Replace the air filter element. Also change engine oil if necessary (mobil 10w30 synthetic.
SOURCE: pressure washer won`t pressure up
Have you tried adding 30 wheight pump oil,under 1 qrt usually
SOURCE: Honda Pressure Washer HP 5 not starting
You can try spraying some carburetor cleaner into the carb. If it starts for a minute, your carburetor need cleaning. When you added new gas did you remove the old gas first? Is the air filter clean?
SOURCE: Karcher pressure washer with Honda GC160 engine only runs on chok
You need to remove the carb bowl, then with a small flat screwdriver remove the jet. ( on the side, at the bottom of stem.) take a small wire or toothpick and clean the gunk out of the jet, reassemble and open fuel valve, start, and pat yourself on your back.
SOURCE: 11 hp honda pressure washer
if you replaced the coil,check the wire and boot,check with meter for continuity.could be loose connection to spark plug
