This camera has been sitting in the closet for a few years. I took it out and charged the battery. It will show me the last photo I took but it won't take new pictures. I've tried pushing every button.
SOURCE: Camera won't take pictures
now u just need to replace the mainboard..... it´s pretty normal for then to go off if u don´t use it in the conditions they were made to.
SOURCE: Can't get photo's out of camera
You can't, they are not actually saved because without a memory card you are in DEMO MODE
SOURCE: Nikon Coolpix L110 camera was
You have to charge the batteries for nearly 8-10 hours. Brand new batteries also require a full recharge of 8-10 hours.Not only making sure the batteries are charged, have you changed the battery in the menu under type of batteries.
Download this manual :
http://www.nikonusa.com/pdf/manuals/noprint/L110_ENnoprint.pdf and go to page #114
Buy EN-MH2-B4/MH-73 Kit (4 Rechargeable Batteries + Charger)
SOURCE: lens error for coolpix l3. The lens won't
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
SOURCE: nikon coolpix s80 won't charge
If its under a year old, you should be able to take it back to the vendor for replacement or repair under warranty. You'll need a proof of purchase.
