SOURCE: cant program directtv remote to sony tv
I'm not sure of your model number but those remotes use the NEC codes and the variants on the NEC codes. If that code set is not the databse, you may have to "learn" it on your particular remote.
Good luck
SOURCE: NO DTV CHANNELS
There may be an input button on the remote, or on the TV, that allows you to switch from the standard ATSC tuner to the DTV tuner.
Let me know if you can't find it and I will dig for an owner manual. But the above should allow you to switch tuners and input sources.
SOURCE: Samsung LE32R74BDX 32 in......
just spoke to Samsung support and it turns out that the freeview tuner had froze and needed resetting. To do this put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Press the 'down arrow' untill you've highlighted option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new. Set the time and country options and then it will perform a complete scan. I've just retuned mine and all back to normal. Hoorah!!!! :-)
SOURCE: SAMASUNG 32 INCH TV FROZEN ON DTV CHANNEL 1
These are the steps to reset the DTV features and unfreeze your TV:
I hope that helps.
SOURCE: Freeview channels (DTV) on a Sharp Aquos TV
On my Aquos it's saying no carrier and database empty what do I do, I have trying to reset TV but free view isn't coming on and it's saying carrier 0.
can anyone help
