SOURCE: is it possible to replace sound card on emachines T3604
You you could replace it... np...
But it could be just a Driver or Software issue. I would update the Audio Driver... go to: http://www.emachines.com/support/drivers.html and locate your PC Model the Download the Audio Driver. It shows 2... use the first one. If that fails try the second one... the second one will write over the first...
If both fail... then if you want to do it youself... head to a PC store. If you are mechanically inclined and can read directions... I would try it youself.
You will need a PCI Audio Card... Install it at the very bottom or last Slot in the System. Of course Power unplugged and again follow the instructions.
Here,..........put your face close to the monitor.......................
S-L-A-A-A-P!
What were you thinking? lol!
The eMachines T3604 Desktop PC uses an Intel D945GCL motherboard,
http://www.intel.com/p/en_US/support/highlights/dsktpboards/d945gcl?wapkw=d945gcl
Advanced > Chipset Configuration Menu > Memory Frequency?
http://download.intel.com/support/motherboards/desktop/sb/biosglossarybymenu_v13.pdf
Well here is the cure,
http://www.intel.com/support/motherboards/desktop/sb/CS-023360.htm
Regards,
joecoolvette
