Question about FoodSaver V3835 Stainless Steel, FoodSaver
Poor evacuation of air
Devices does not completely evacuate the air before sealing
Cannot get it to vacuum.
Does it try to vacuum but never flattens the bag? Make sure the bag you are using is completely sealed on the opposite end. Otherwise, the seal on the sealer is probably allowing air to leak into the sealer. If it has a foam sealer, I've found it sometimes helps to run the foam sealer under water, squeeze out the excess water, reinsert the foam sealer (make sure it is seated all the way) and then try again to seal the bag.
Mar 07, 2016 | FoodSaver Food Saver Vacuum Sealer...
Seals but won't draw all the air out. Seals fine
That could be a bad foam seal not completing suction, A piece of debris that got sucked into vacuum line and or in pump, or in some cases a crack in a elbow or pump housing.
Jan 22, 2016 | FoodSaver Vacuum Sealer Kit V3460
Do I need to bench bleed my new master cylinder? I have installed a new master cylinder and put new brake fluid in it and replaced some of the brake lines. I'm using one of the Vacula vacuum pump blee
I be leave the bench bleed is standard protocol but if it is already installed you may need to power bleed it. this is easier in a shop unless you have the tools.
Oct 08, 2014 | Vacula DX 2.5 Brake Bleeder/Flusher and...
Electrolux cyclone power 1900w no suction with main attachment
If you've tried several different attachments and they all exhibit the same poor suction problems, you should completely check the parts of the vac that are common to all the parts that have the problem.
Since the motor creates good suction without attachments, I suspect the problem is the hose. Either an obstruction or a crack. Typically, if you block the end of the hose, the pitch of the motor's sound will go up slightly - like it it is spinning faster (it is). You can keep removing parts from the vac intake until the motors sound decreases - and that will indicate the part that has the obstruction. If it is a hose, you should clear the obstruction with a "snake" or other object like a pole.
If the motor sound does not change, then there is likely a split or crack somewhere between the intake of the vac and the device. You'll have to check it carefully - or if possible - connect it to the output of a vac and seal / cover the end. Feel along the length of the hose, etc. for air being blown out. Repair the opening and you should be "good to go"
May 12, 2012 | Electrolux Vacuums
Plugged in the charger to my model AV-701B electric broom after not using for a few months. Charging lamp went green as soon as I plugged it in. Unplugged the unit but it will not turn on.
The same happened to me. The battery will no longer take a charge. Oreck store was of no help. Do NOT buy the new model it is poorly designed. you can find other brands in the same category at half the price and much better brands for about the same price.
rudy
Oct 08, 2010 | Oreck ElectrikBroom AV-701B Handheld...
Not picking up dirty water off floor.
NORMALLY SUCTION PROBLEMS ARE CAUSED BY A POOR SEALING PROBLEM OR AIR LEEK. CHECK ALL BLACK RUBBER SEALS TO BE SURE THEY ARE SEATED CORRECTLY, NOT WORN OUT OR TORN. BE SURE FILTER AND TOP TO FILTER ARE IN PLACE, AND YOU MIGHT WANT TO LUBRICATE SEALS AND CONNECTION WITH A LITTLE VASILINE OR CRISCO IF YOU ARE A MOM LIKE ME. MINE IS WORKING FINE NOW, HOPE THIS HELPS.
Feb 06, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
It is making a whistling sound and is losing suction
Make sure the top (above the cones) and the bottom (ball) filters are clean. The whistling sound is due to the bottom filter either being clogged or poorly seated and the air is escaping around the rubber seal, making the whistling sound.
Feb 03, 2010 | Dyson DC15 All Floors - The Ball Bagless...
Theres no spray coming out but theres solution in. ive checked seals, turned off left it and primed it. it works for 1 stroke then im bk to square one again. please help me
You need to check the seals. It is loosing prime after one stroke. I had the same problem and found obstructions causing a seal to leak and allowing air into the sytem. Take it completely apart and clean thouroughly.Also do you have the dial to choose between carpet and tools? If so make sure its not on the tool setting. I have done this numerous times only to find out i forgot to change it back
Sep 29, 2009 | Bissell 1698 PowerSteamer ProHeat Upright...
What is vaccum packing?
Vacuum packing is a method of storing food and presenting it for sale. Appropriate types of food are stored in an airless environment, usually in an air-tight pack or bottle to prevent the growth of microorganisms. The vacuum environment removes atmospheric oxygen, protecting the food from spoiling by limiting the growth of aerobic bacteria or fungi, and preventing the evaporation of volatile components. Vacuum packing is commonly used for long-term storage of dry foods such as cereals, nuts, cured meats, cheese, smoked fish, coffee, and crisps and also for shorter-term storage of fresh foods such as vegetables, meats, and liquids such as soups.
Vacuum packing is also used to reduce greatly the bulk of non-food items. For example, clothing and bedding can be stored in bags evacuated with a domestic vacuum cleaner or a dedicated vacuum sealer. This technique is sometimes used to compact household waste, for example where a charge is made for each full bag collected.
Please rate this fixya
Jan 29, 2009 | Vacuums
Eureka Bravo II poor suction at hose
check if the hose is clogged or the fan is broken
Jan 04, 2009 | Eureka 7606 Bagged Upright Vacuum
FoodSaver V3835 Stainless Steel, FoodSaver Logo
15 people viewed this question
Top FoodSaver Vacuums Experts
Lawrence Oravetz
Irene Tulloch
ray gallant
Are you a FoodSaver Vacuum Expert? Answer questions, earn points and help others
