Televison & Video Logo
B
Bonnie Fortini Posted on Aug 07, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung TV won't turn on after lightening storm. Surge protector "sparked once, but all the other things plugged in are operating.
Have tried resetting (pulling plug, depressing power switch, different power source), but still no red light. Screen fluctuates between black and dark gray if plugged in.
Level 3:
  • Samsung Master 19,187 Answers
  • Posted on Aug 07, 2014
Samsung Master
Level 3:
Answers
19187
Questions
0
Helped
4345934
Points
82261
Contact your insurance company and make a claim. Lightning damage to electronics like that is hard to repair.
5 Related Answers
Anonymous
  • 192 Answers
  • Posted on Apr 29, 2007
SOURCE: blinking power light
This set has a power supply and signal PCB. Since the indicator light is blinking, I would consider the problem to be a missing voltage from the power supply. Unplugging the set for a couple minutes may solve the problem. If not the set may still be under warranty. Contact LG (800) 243-0000 for a servicer in your area. Hope this helps.
bestdarngood
Benjamin Patri
  • 3037 Answers
  • Posted on Oct 26, 2008
SOURCE: screen went black/won't power on
This is a common problem
The first step is to check the fuse on the power supply board. Next, disconnect the inverter board to eliminate the possibility of it shorting down the main and or power boards. Be careful as the inverter board supplies high voltage to the cold cathode tubes (backlights) and it bites HARD. If you disconnect the inverter and the power led comes up then replace the inverter board. (The screen will appear blank because you have no backlighting). If the power indicator still fails to light you need to suspect the main board first before the powwer supply board. The main board tells the power supply board to come on. You need to check the trigger from the main board to the relays on the power supply board. Also check the power connector to the main board because you should see +12V and/or +5V on at least some of the pins. If no power on the relay triggers then replace logic board. Then replace Power supply board last. Or buy a new monitor!!
Quickfx PC Repair
  • 846 Answers
  • Posted on Jul 15, 2009
SOURCE: No power on Samsung TV after storm
Hello Zkarim,
I'm very sorry to hear about your unfortunate new's. I had the same problem in my own home maybe a week ago.
Basically if your power flickered on and off at anytime during this storm then there was a power surge that probably fried your TV.
* First check the power where the tv was plugged in. Is it a power strip or a surge protector ? Surge protectors typically have an on/off switch and a separate reset push button.
If it is a power strip then the tv fried because there was nothing to stop it from happening (not even the fuse). If it was plugged into a surge protector then it could be quiet a few years old and not as reliable or the surge was to powerful for the limit on the surge protector.
The only thing you can do personally is send it in for repair if it's under warranty, if it is not then you can have it looked at by an authorized repair technician in your area. Troubleshooting should be fairly low, and you will at least be able to find out your options once they find the defected part.
Thank you for choosing Fixya!
Anonymous
  • 15 Answers
  • Posted on Jul 28, 2009
SOURCE: 50 inch Plasma Samsung HP-T5054 appears to have power however...
check the power inverter on the power strip. also check the caps on the board and if any of those caps have a round top it is bad and needs to be replaced. i hope this helps.
Anonymous
  • 117 Answers
  • Posted on Dec 26, 2009
SOURCE: Samsung LN52A650 lcd will not turn on after power
open it up / there should be a glass fuse replace it/ull find it were the mains lead goes on the board/also try new lead just incase
After a lightening storm, my power surge strip got hit and damaged everything that was attached to it (i.e. the internet modem, blu-ray player, and Samsung TV). Our TV only has a blue screen. Help
Yep, power spikes kill. Power spikes kill all. Power spikes kill all forever. Replace all and get a new surge protector that costs at least $99. If you never need it it is called insurance. I am in FL the capitol of lightning. High priced surge protectors are cheeeeep when lightning is there.
1helpful
My HDTV went out in a lightening storm. What could it be?
Is your TV plugged into a surge protector? If not it very well may have gotten a power surge during the lightening storm that fried components in the TV.
Or is the TV connected to a cable box? It could be that the cable box took the hit if it's not plugged into a surge protector.
Or a possibility of both.
Lightening caused surge protector to "spark" but no power loss, and everything plugged in works except the Samsung HDTV
Hi, In a lighting storm you are supposed to unplug your TV. In this case you may have fried something on main board. Take it to repairman. Good luck.
Where do I find the part number on the power board for my LG 47LH40
You have to contact the authorized service centre for LG, to get an original replacement.
My lg tv won't turn on after a lightening storm
Your surge protector did not function properly, contact the manufacturer of the power strip.
1helpful
We had lighnting storm pass by and our TV was plugged into a surge protector along with many other devices. When the storm passed the TV will not turn on anymore.
Likely, the surge protector failed.
Depending on the manufacturer, you may have some sort of warranty available. That is, the manufacturer of the surge protector may reimburse you for the cost of TV repairs.
But foremost, try plugging the TV directly into the wall. It could be that the socket or surge protector were fried, but your TV is ok.
2helpful
Hello Zkarim,
1helpful
We had a near lightning strike and now my tv (sanyo model ht27744)doesn't want to come on.
Lightening may have caused a surge on your power lines to the house and to the outlet the TV was on.
Do other things work on that outlet? If not you tripped a power breaker.If they do work check this.
Unplug the TV for 2 min or more and plug back in.
Try bypassing your surge protector you had it plugged into. It could have died when the lightening struck.
(no surge protector?) Bet you'll buy one for your next TV.
Look for 3000 joules and up rating for a surge protector and insure it has protection for a cable/antenna input too.
If this doesn't work the TV may be fried or internal fuse blown.
Time to take it to a repair shop or depending on it's age (5 years+) it may be time to buy a new TV and surge protector.
Near Lightening strikes can effect appliances from several inputs that could be affected from outside like Power, Cable, Antennas, Phone Lines that come into your house.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
