Washer- During the first drain cycle, it does not sound like it is draining. Then during rinse cycle it begins to overflow and leak out of the bottom. What can we do to fix this?
SOURCE: HELP!! Leaks!! Leaks!!!
the inner tub and outer tub has a seal under the agitator. this must be replaced. use a spanner or a large channel lock plier to remove the nut. seal is underneath it.
SOURCE: Frigidaire washer machine #FWTBB30DS0
check to see if your drain hose is too far down in the stand pipe this will siphon water out as it fills.
SOURCE: model # glws1233as2 my washer is leaking water
hi
it is outlet valve problem...replace and see ur problem will be solved///thank u
please rate it
SOURCE: the front load washer stopped during the rinse
You have a clogged drain pump. The best way to access the pump is to remove the back panel and take of drain hose. Clear out the pump and test, everything should be ok
