Remove screen
I assume you are talking abou tthe screen on the faucet where the water comes out. that cap (usually) simply unscrews. it can get stuck over time when that happens i put a wash cloth around it then use pliers to loosen it once the cap is off the screen is usually inside the cap. along with a plastic aireator.. hope that helps
SOURCE: american standard kitchen faucet leaking
soak down with WD40 and try again use a bigger wrench they all come off i have not found any that i have not been able remove!
SOURCE: how to replace sprout seal kit in american standard faucet ?
just pull straight up,wiggle back and forth,the o-rings are holding it on .
SOURCE: American Standard Colony Soft gooseneck kitchen faucet leaks base
at the spout near the base is an echeion ring. turn this counterclock wise then pull up ring to expose the neck,pull spout straight up.this echeion cap holds on the spout to the base there are plastic parts inside so be careful when pulling apart.
SOURCE: I have an american standard bathroom faucet.
First, turn off the water supply under the sink. Next, put the faucet lever in the up position, no water should be coming out. While in the up position turn slowly while looking at the underside of the handle and you should be able to find a set screw. It will probable be an "allen head" type and you will need and allen head wrench to loosen it. An allen head looks like a hex shape, 6 sided I believe and is rod shaped. If you don't have one they come in sets at your local hardeware.
SOURCE: I have an American Standard bathroom faucet. The
Assuming the drain plug is the pop-up type where you pull a small rod up behind the faucet, you can try the following:
In the cabinet below the sink you will see the rod come down that operates the sink drain plug. There is a horizontal rod connected to this that goes into the drain line with a small round cap. Unscrew this cap and pull the rod out. The drain plug should come up freely from the drain.
After cleaning reinsert the drain plug and be sure the horizontal rod goes into the drain and through the hole at the bottom of the drain plug shaft. Seat the round ball from the horizontal shaft into the drain line and tighten the round cap to hold the horizontal rod in the drain.
