Codes for fios
0029,0022,0067,0038.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
SOURCE: Sylvania LC155SC8 remote TV code for Verizon Fios
buy the radio shack "6 in 1 remote. It has a "learning" mode that picked up all my needed commands from both my verizon fios remote and my new sylvania hdtv remote. works perfectly.
SOURCE: Sylvania remote no taking Verzon fios codes
I had the same problem, the only way I was able to fix this problem which drove me nuts, was to by a learning remote.
I bought a nice Sharper Image Large Remote with lited buttons for $15.00. It did the trick, and will learn any remote and it's buttons.
SOURCE: my Sylvania LC320SSX TV
If dead then its your power supply bad, if you have led lights and no picture then it could be inverter board.
SOURCE: Sylvania LC320SSX HDTV no longer
Required power supply board is available in shopjimmy.com
Testimonial: "Thyanks for the updated info."
