SOURCE: card reader driver doesn't work
there could be two problem. first is that the memory card would have pasword. is so than insert it to the mobile and nutralise the sd card. second is that you might not have the driver for it. for downloading driver, go to this link http://download.cnet.com/1770-20_4-0.html?query=sony+vaio+sd+slot+driver&tag=srch&searchtype=downloads&filterName=platform%3DWindows&filter=platform%3DWindows
SOURCE: Need service manual or instructions on replacing
The hard drive is inside of the laptop and not accessible from the outside. The way to get to the hard drive is to take out all the screws from the bottom of the laptop, take the keyboard out and there may be some screws there that need to be removed. The dvd drive needs to come out and where the dvd drive normally is, check for screws there.
At this point you can remove the top cover assembly and you will see the hard drive. Remove the screws that are holding the hard drive in place and then it will come out.
Testimonial: "Thanks I realize that the unit needed to be seperated however without a service manual there may be some important tips that could be missed."
SOURCE: I have recently installed Windows
I checked the information and found that the computer does not qualify for a Windows 7 Upgrade from Sony. But as we have tried, Windows Vista drivers work with Windows 7 as the core for both the OS is same. I suggest that you download install Memory Card driver for Windows Vista from the below link to resolve the issue with the SD Card. I have also provided the link to download Sony Shared Library which you should install first.
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNN250EB&upd_id=2383&os_id=28
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNN250EB&upd_id=2416&os_id=28
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNN250EB&upd_id=2391&os_id=28
Thanks!!!!
SOURCE: i cant remember the
You can reset the BIOS password. To reset the BIOS password read the information from this link.
You can download the device drivers from the Sony WEB site.
Select your model notebook and the Windows drivers you require. Pleaseclick on this link to the Sony support WEB site :-
http://esupport.sony.com/US/perl/select-system.pl?PRODTYPE=1,24,72&DIRECTOR=DRIVER
