It's possible that you had a surge when the power returned that scrambled the controller's brain. Try disconnecting power and reconnecting to restore normal operation. Disconnect power by unplugging the stove from the wall or switching off the breaker that controls it at your main circuit breaker box. Wait a minute or two, then plug the stove back in or turn the circuit breaker back on. If the stove does not work after this, you may need a new controller board.
Hi friend, thank you for your inquiry!
I understand that you are receiving an "ER" error code on your Frigidaire range and you want to clear the code. "ER" stands for error, I would recommend performing a reset which can be done by flipping the household circuit breaker for roughly ten minutes. That should clear any false error codes. If you continue to receive an "ER" or any different codes please provide that feedback. I hope this helps. -Matt
