I bought a refurbished Tom tom GPS and the display is mostly in a foreign language . How do I fix this
Best to reset to factory settings and then reconfigure the unit as per instructions in the attached manual. All the maps and data will be lost and you will have to re-install. So make sure you have access to the map files which can be reloaded after the settings are complete.
Reset button is shown in diagram on page 2. Good luck. http://download.tomtom.com/open/manuals/one3rd/refman/TomTom-ONEv3-en-GB.pdf
SOURCE: Tom Tom One
get to the navigation screen and tap the screen, there should be a spanner icon, which is the change preferences icon, tap this, click on the arrow three times until you come to a screen with flags on it, you should be able to select english Uk from the screen
SOURCE: tomtom in foreign language need english
on you main menu go to the wrench picture, that is change preferences. Then touch the arrow, above done on the screen 3 times til you reach the screen that has "3 flags flying. that is the icon to change language. touch that, choose english us and you're done.
i had the same problem. take care
SOURCE: TOM TOM GPS Updates
That depends on where you got it and if the documentation for the updates was in the box.
Usually the answer is yes.
Those from Tiger Direct do.
I have used it before now with few problems.
Couple of times I have had to talk to them but they have always been good and given me a code or new code to get the updates.
SOURCE: tomtom GPS language setting
Do this whilst it is disconnect from a PC
Whilst it shows a map display touch the screen once.
Select the icon that looks like a spanner / wrench
Use the rght arrow on the display until you see a bunch of flags. (if you shoot past it just keep going until it comes ound again)
Touch that and select the correct the correct flag / language.
SOURCE: HOw can i change the language on my tom tom gps
follow the directions below and look for the icon of the flags...tap main map screen then preferences (little wrench icon) then use the arrow on the bottom right to page to the language icon...i think its the fourth page ...then select the language you want.
bill
bill
Follow the instructions on the screen to confirm your language selection and choose a voice.
