Is there a manufactor recall on control board?? red light stays on/ beeps.
SOURCE: Red light showing high tempature
cooling temperature of freezing is damaged and also damaged heater machine which keep in deep freeze but controller point keep in normal side,you must be repair that problem as soon as possible otherwise full freezing system get damaged.
Hello friend, thanks for the post!
I see that the red light stays on and your Frigidaire freezer continues to beep. From what I have researched there is no recall on the control board of FFU17F5HWH. You could try resetting your appliance, which could be done by unplugging the power cord or flipping the household circuit breaker in the off position for ten minutes. Please comment back I would like to know if this information has been helpful. I look forward to your post. -Matt
You may need to reset the unit at the household circuit breaker for a few minutes to create a hard reset within the unit. Then retry. If it proves to be ineffective, the unit may possibly be experiencing a communication problem with the temperature control/board or wiring failure. Contact a professional to move forward accurately.
