Question about Sta Rite Maxi Therm 400k Btu Propane Heater
What r13 code mean - Sta Rite Maxi Therm 400k Btu Propane Heater
    New Friend:
  • 61 Answers
There is no r13 code on your heater. The r13 flashes everytime you turn on your heater, wait, then see if it fires, if not, you will get an error code starting with EO then a number, or the "service system" or "service heater" light will come on.
Posted on Aug 13, 2014
6ya staff
SOURCE:
Explain the code error r9 and what is the solution
I don't have a definite solution however r9 is a heater problem it could be a short curuit between the heater and ground make sure the ground wire has not become loose or corroded
Jul 19, 2015 | Washing Machines
Sta-Rite SR400 heater displays error r13
this is not an error code, its the startup sequence to your heater. after those numbers have been displayed you have to press the pool on button and set your temperature
Dec 28, 2014 | Pool & Spa
Heater does't fire. led appear 128,r13 what's problem?
128 r13 is not an error code. its the startup sequence of that heater
May 14, 2014 | Pentair Mastertemp Heater
Mobitronic mps50A components
Hello Brenden,
Did you find the value for r13 on the Mobitronics MPS-50A power supply?
I am looking for that value also.
I
cannot locate where R13 is on the board so if you give me some direction I may be able to help.
I do not have a diagram just a power supply that I am trying to repair also.
Cheers
Stewart
Sydney
Australia
Nov 13, 2011 | Washing Machines
I have a Ford Escort 55 Van that has now been put onto Spanish plates & I have a problem with the Spanish log book as they have stated that the tyres must be 165 R13 82H, these are specialist due to...
Rim size 5x13 tyre size 155 R13 78T
5.5 x13 175/70 R13 82H/T
6 x 14 175/65 R14 82H
6 x 14 185/60 R14 82H
6 x 14 185/60 R14 V
6 x 15 195/50 R15 V
This Ford recommend to Escort.
Aug 10, 2011 | Ford Escort Cars & Trucks
Type of freon need in 88 fith avenue
R13 refrigerant. This refrigerant is hard to find nowadays but a conversion kit from R13 to R134a is probably to best thing to do because R134a refrigerant is everywhere.
Jun 01, 2011 | 1988 Chrysler Fifth Avenue
I have a Pyramid PS-52kx. I need to know the value of R13 on the controller board, and cross-reference for TYN416
I HAVE A PYRAMID PS-52KX I NEED TO KNOW THE R13 RESISTOR OHMS AN TOLARENCE AND WATT.
Mar 07, 2011 | Pyramid PS52K Amplifier
Purchased Buffet r13 (serial # 555623) new, six months ago. Still under warranty. Since then have had technicians try to adjust mid b c key problems as well as others. R13 B660 is burned into the barrel....
The model designation for R13s is not usually on the upper and lower joints. If it was a Prestige, Tosca etc, it might have a little metal plaque on the top joint, but not on a regular R13.
Perhaps you could try a different repair technician - your run of the mill instrument repair person (even the guy who works where you bought it!) may not have the skills needed to really fine tune a professional instrument.
Apr 20, 2010 | Clarinet Systems Clarinet EthIR STAR 1000...
I want to know if i could use r13 in a 1998 ford explorer
I would not use R13 in place of R134a...not sure the two are compatible. R134a is cheap and sold at all auto parts stores...
Jun 25, 2009 | 1998 Ford Explorer
Sta Rite Maxi Therm 400k Btu Propane Heater  Logo
2,978 people viewed this question
Top Sta Rite Pool & Spa Experts
US Parts Center
US Parts Center
john h
Mike
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
