Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
A
Anonymous Posted on Aug 05, 2014
Dyson 07 wand cap removal
How do I remove the wand cap?
Charles Houlroyd
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 124 Answers
  • Posted on Aug 14, 2014
Charles Houlroyd
Expert
Level 2:
New Friend:
Cheetah:
Answers
124
Questions
0
Helped
65184
Points
268
Http://www.dyson.com/support/dc17/dc17-animal/diagnosis-root-menu/dc17filterwashvid/flo-dc17-wand-suction/flo-dc17-remove-the-wand-from-hose - This should help you!
I’m happy to help further over the phone at https://www.6ya.com/expert/charles_6bf94c079488b145
5 Related Answers
Anonymous
  • 83 Answers
  • Posted on Jul 30, 2009
SOURCE: Dyson DC-07 Hose Wand Spring Came Out. How to put back in?
You'll see that there is a round piece with a cross shape on the inside of the button wand release button - place the end of the spring over the cross - you'll see the same cross on the collar of the machine...it'll take some doing, but line the other end of the spring up with the cross and pop the button back into place - be sure to click it onto those two gray circular/oval shaped divets at the bottom where the release button connects to so that the button stays in place.
Anonymous
  • 83 Answers
SOURCE: dyson dc25 animal: cannot remove the telescope
The hose is getting twisted on the machine and so the wand gets stuck in the hose.
1) Pull the wand out as far as you can - if you can pull it out completely, separate it from the hose and apply baby powder to the
metal rod. Stretch out the hose and unwind it. In the future, separate the wand and unwind/stretch the hose after use.
2) If you can't pull the wand out all the way, remove the canister/dirt bin from the front. Look for a gray button with 7 vertical
lines/grooves on it (it'll be just above the ball on the opposite side of the bottom hook that you wind the cable around).
3) Push the button and at the same time pull the hose out from the bottom by pulling on the hook - this will release the gray hose
from the machine. Take it off of the machine if possible (the bottom of the wand may stop you from doing so - if it does, try to pull
the wand out until you can release the hose from the bottom)
4) Pull and stretch the hose out and pull the wand at the same time - separate the wand from the hose and unwind the gray hose and
stretch it out. Rub baby powder on the metal rod of the wand and in future, disconnect the wand from the hose and stretch/unwind the
hose after every time you use the wand.
Anonymous
  • 167 Answers
  • Posted on Apr 20, 2010
SOURCE: I cant remove my wand on my Dyson vacuum.
Hi its Darran at Dyson.
It is possible that if the hose is blocked that the wand handle may become jammed. For help releasing this, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US) and one of our advisors can talk you through releasing this.
Kind regards
Darran
Dyson Customer Service
Anonymous
  • Posted on Aug 09, 2011
SOURCE: Hi. I have a Dyson
I think I figured this out. If the hose gets twisted too many times while being used, the pole has a hard time going in and out for removal. (Kind of like how old phone cords got all twisted up after use for a while) To get it out, lift the pole out as far as you can then tug on the hose pulling it down & out ways until you can work the pole all the way up to get it out. Once out, detach the hose from the wand and turn it a few time (I had to go counter clockwise) to un twist the hose a little. Seemed to fix this problem for me.
askdyson
AskDyson
  • 2572 Answers
  • Posted on Nov 22, 2011
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: the wand on my dyson does not work
    Hi Colleen,
    I've responded to your previous question in the Dyson DC15 category, but if the model you own is actually a DC24, the directions for checking everything is correct with the machine will be slightly different. Please follow the steps shown in this support guide instead:
    http://www.dyson.co.uk/support/help.asp?article=1492&product=DC24-ALLFLOORS
    If you can't find any blockages but are still concerned about performance through the hose, please call us free on 0800 298 0298 (UK), or 1866MYDYSON (US) so we can help.
    Kind regards,
    Jack
    Dyson Online Customer Support
    Wand pulls out but sticks when there is still about 2 inches to go before able to close cap on wand
    You might have an obstruction somewhere or something is keeping a valve that directs the airflow from the floor to the wand from moving properly. You will need to investigate all these areas to determine what is nor operating properly.
    1helpful
    A Dyson dc 17 Animal and the wand/hose has lost suction
    From your description of the problem, it sounds as though the wand/hose is blocked. To check this, remove the wand/hose assembly from the machine, switch it on and test the suction from the top of the wand with your hand. If the suction is poor, remove the wand from the hose and test the suction from the top of the hose. If its good here, then you know that the wand handle is blocked.
    For the full diagnostics, check out the Support section on our website at www.dyson.com or call our Helpline on 1866MYDYSON.
    Kind regards
    Darran
    I just bought a used Dyson DC07. Works good but
    From your description of the problem, it sounds as though the wand/hose is blocked. To test this, please remove the wand from the machine and switch on, testing the suction from the top of the wand handle. If the suction is poor, remove the wand from the hose and test the suction from the top of the hose. If its strong from the hose itself, the wand is blocked and you will need to clear this.
    If there is poor suction from the hose, you can remove this by unclipping it from the base of the machine and can then remove any blockages. It is also worth checking the hose for any splits or holes.
    If you need any further help or advice, please visit our website at www.dyson.com and check out our support section.
    Kind regards
    Darran
    7helpful
    2answers
    No suction on wand of Dyson DC14 Animal
    It sounds as though the wand handle is blocked. To check this, remove the wand/hose from the machine as if you were going to use it to vacuum the stairs. Switch the machine on and test the suction at the top of the wand handle with your hand. If the suction from the wand is poor, remove the wand from the hose and test the suction again from the top of the hose. If the suction here is good, then you know the wand handle is blocked. If the suction is poor at the hose, you can remove the hose from the machine and clear any blockages here.
    For the full blockage procedure please visit the support section on our website at www.dyson.com.
    Kind regards
    Darran
    Dyson customer Service
    No vaccum at the hose attachment, the main powerhead has vaccum
    You may have a blockage somewhere. Take the U-Bend (next to the right-hand wheel if you stand behind the vacuum cleaner) off. It is attached to the vacuum with a rectangular-shaped clip - it's purple. It is the pipe that is attached under the long gray hose. After that take out the AI Valve (the pipe above the right-hand side wheel) that has two purple buttons to remove it. Take the wand off and look through it - you should see light coming through the other end even though the wand is not straight all the way. If you can't see light through the other end the blockage is in the wand. Stretch the hose out and make sure there are no dark spots inside - those would be blockages. If all else fails call the Dyson helpline, they'll help you.
    1helpful
    Vacuum wand won't retract fully into it's compartment.
    HI,
    FIRSTLY DETACH WAND FROM UNIT AND SLIDE HOSE DOWN AS FAR AS IT GOES, SPRAY A LITTLE WD40 OVER WAND AND SLIDE HOSE UP AND DOWN, AS FOR THE CAP, TAKE A PAIR OF PLIARS, GRAB HOLD OF END OF CAP AND PULL CAP FULLY OUT OF THE HANDLE,AT THIS POINT CHECK THE SPRING OR REMOVE THE SPRING IF YOU PREFER AND PUSH THE CAP BACK INTO HANDLE AND THAT WILL DO IT FOR YOU.
    REGARDS
    DAZ
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Sean Wright
    Sean Wright
    xxxxxx xxx
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
