Ovens Logo
A
Anonymous Posted on Aug 05, 2014
What is an EOC - Frigidaire Ovens
  • Official Brand Answer 2,267 Answers
  • Posted on Aug 06, 2014
Frigidaire
Level 0:
Answers
2267
Questions
0
Helped
1289971
Points
2557
Good Afternoon Friend, this is. Z. That's a great question.
The EOC (Electronic Oven Control) provides power for all oven operations (i.e. Bake, Broil, Convection Elements, Convection Fans, Lights and etc.) Hope this helps!
2helpful
2answers
F10 oven code frequently beeps,often after cooking is over and oven is coolind down at different temperature settings tempermental some times it works sometimes it does not.
The "F10" error code caused by the runaway temperature.
The first thing I would check is the resistance across the oven temperature probe (aka oven temperature sensor) terminals at the EOC (electronic oven control) plug.
It suppose to be about 1100 Ohms at the room temperature.
If the resistance at the EOC plug is wrong, then measure the oven temperature probe resistance at the probe plug.
If it's wrong - replace the oven temperature probe. It's better to hardwire it, using a high temperature ceramic wire nuts.
If the readings at the EOC and at the oven temperature probe plug are different - check the wire harness between the oven temperature probe and the EOC.
If there is nothing wrong with the oven temperature probe resistance - replace the EOC.
2helpful
Was cleaning oven and error code F10 appeared what is a error code F10?
hello there"
- The part number for the oven temperature probe is AP3704441
- The part number for the EOC is AP3776874
- The part number for the EOC overlay is AP3778486
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/4431-f10-error-code.html#ixzz156CO7RjB
Have a whirlpool gold black oven and nothing works on the electronic oven control panel but the burners on top work. what could be the problem? thanks, dan
Hello Dan. You most likely need a new EOC (oven control) / clock. These are often expensive but fairly easy to change. If you do decide to try to replace it BE SURE that it is unplugged or the breaker is off. Usually if you pull the range out from the wall (be careful of scratching your floors, put cardboard under the front legs) you can access the EOC from the back of the control panel. There should be a cover over the back of the control with a lot of screws, remove as many as you need to have access to the EOC. It should be evident how to remove the EOC once you see it, often just 4 screws. Have the new one on hand and just be careful when removing wires and make a little diagram if you need to help you remember where they go on the new unit. One thing to consider once you get the cost of the EOC/Clock take a look at the cost of a new range. Sometimes these parts are half the cost of a new range. Hope this helps, best regards.
1helpful
Quatre par convection Erreur auto Frigidaire Nettoyant f 3 et f 1
F3 -The oven temperature sensor is open
Check for open wire connection between EOC (Electronic Oven Control - Clock) and the oven temperature sensor. Replace sensor if no wiring problem.
F1- EOC (Electronic Oven Control) failure
Replace EOC (Electronic Oven Control)
Thank You
My Frigidaire Oven display panel won't come on all of a sudden. Burners and oven light work. It could be from a surge in electricity. How do I 1) check fuses or breaker? Where are these located? How could...
If the burners and oven light are working, then you have power coming in. It's most likely a defective EOC. If you haven't tried turning off the circuit breaker for 5-10 mins to reset any glitch associated with a surge or spike, do so. If this doesn't reset the control, the EOC will need to be replaced.
1helpful
Error code F7
your problem is with the EOC (Electronic oven control) or touch pad if it is seperate from the control...if the touch pad is seperate...unplug range - access the control panel - remove the wiring/tape wire from touchpad to EOC...plug range back in...leave over night...if f7 code comes back it's the EOC...if the error code clears it's the touchpad...replace the part with the problem...if touchpad built into EOC replace the EOC. Hope this helps...if you have any other questions please feel free to comment again.
Jul 06, 2009 • GE Ovens
F 10 code when I try using oven
The first thing I would check is the resistance across the oven temperature probe (oven temperature sensor) terminals at the EOC (electronic oven control) plug.
It will be about 1100 Ohms at the room temperature.
Please rate and have a great day:)
3helpful
F7 error code- what does this mean?
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
Display Condition Remedy
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1helpful
Beeping F11
F11  is a keypad short. This was actually a simple fix when I got into it. Take off the top rear panel. You will need a drill driver or #2 square drive. Once inside: the EOC is held in by 4 screws. Remove those and pull out the EOC.
My diagnosis on the problem is this: The keypad connection to the EOC is the thin plastic serial connector on the top of the unit, looping to the back. What I figure is that this plastic must have the  tendency to warp under the influence of heat and  thus reduces the good connection to the serial input on the EOC. There is a black plastic connection protector on the input side of the serial connector at the EOC. Gently pull this off and pull the serial connector out and give it a good cleaning. Place the serial connector back in the receiver and replace the connection protector back on. ( tricky.  if you have ever built a model or soldered anything you will be fine.)
The serial connection will need some pressure on it  to make a good connection if it is warped. My solution to this was to run a plastic cable tie thru the small holes in the top of the EOC. tighten the cable tie over the serial connector, pressing it to the top of the EOC. This gives it a good pressure on the input pins in the connection input.
Now plug the unit back in. You should have full function of the keypad. If not, it may be another issue with the keypad or EOC.  This was a solution I happened to stumble on and it may not work for everyone but giving it a shot means you might save 170 dollars in parts not including the labor.
Dec 01, 2008 • Ovens
How do you replace EOC?
No code is required. What was sold to me was a broken part. We discovered the transformer on the circuit board was cracked all the way through. The zip tie that encircled this transformer was not part of the shipping packaging as we first thought, but rather was someone's way of fixing the part then sold to me as a new part. I am trying to make contact with Spitfire Controls, the manufacturer of my EOC, to see if they can resolve the warranty issue and exchange this broken EOC with a new EOC. But so far no one has returned may message.
Top Frigidaire Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Kell Le
Level 1 Expert
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
