Camera says Reinsert memory stick I t is in camera!! do I need new one or new camera. Prior to this it was saying no images. Hope you can help.
SOURCE: memory stick for sony cyber-shot
You might try cleaning it with alcohol.
If that doesn't work you'll have to insert the card into a pc and use some kind of data recovery software to do that. I would recommend R-Studio or Get Data Back. Unless you know someone that could do it for you.
SOURCE: Reinsert the memory stick...
you will need to re formatt the card and this problem should be solved
SOURCE: Sony cyber shot DSC S930 "Reinsert Memory Stick"?
I am having the exact same problem and I have only had my camera for 2 weeks. We took it on vacation and I really want my pictures. Did you find a solution? Was it the memory card or ther camera?
SOURCE: Sony Cyber-Shot DSC-T5 "C:13:01 Format Error"
I had the same problem, you can solve this by:
1. Push the card multiple times in/out the slot or
2. Use a little bit of contact spray on a small piece of tissue, rap this in the length around the memory card just 1 time. Be carefull not to make it to thick that it get stuck in the slot. Then push the card multiple times in/out the slot or
3. Cut a small strip of waterproof sanding paper (grain: 400 or more - the surface feels just like paper, and is just a thin as paper) just as wide as the card or slot. Cut a strip of plastic (eg.old credit card) also just as wide as the card or slot. Rap the sanding paper in the length of the strip and insert this in and out the slot. But!! ... make sure you stay at the upper side of the contacts, don't worry just do it carefully, don't use force and sand the contacts a couple of times. This way work for me, finally!!
