I have a GE Spectra XL44, JGBP79.
My oven is not heating up...it does not ignite. I tested the touch pad with a test I found here at FixYa (although for a different model) and the only code that came up was F7 for the Control Board. There is no beeping or flashing of any code. I replaced the board, but the problem is still exactly the same. Thinking it is the ignitor.
The broiler and stove top both work...it is just the oven that is not firing up.
Any ideas/suggestions?
Yes I had the same problem on my JGBBP79. Change the lower igniter. About $75. Keep the range for a few more years and get rid of it. The next problem you'll mostly likely have is the touch pad F1 error. That stupid thing is +$300 and nothing more than a membrane touch pad attached to some glass. :-(
To Adjust
the Thermostat
My oven is not heating up...Temperature stays the same when you turn the oven on.. There is no beeping or flashing to let you know that you have reached the desired temperature.
We are having the same problem with our oven- the broiler and stovetop work but the oven will not heat up. Someone mentioned to change the lower ignitor- any suggestions on how to go about doing that?
