I purchased a pc cd rom copy of pharaoh on ebay and it didn't come with a leaflet or a cd key so I was wondering if anyone could give me a cd key so I can install it? many thanks x
Did u buy a pirated copy? or the person just let you use the cd? either you can ask the seller to provide you the key or search online... google is your friend. :)
ok, many thanks!
it wasn't a pirate copy, it came in a case but with no manual/product key...
ive been searching on google but cant find anything. can you suggest what to put in the search bar? maybe i'm wording it wrong lol :)
SOURCE: D600 Service Pack 1 CD Copy
http://www.google.com/search?hl=en&sitesearch=drivers.com&q=SP1&btnG=Search
just download SP1...
SOURCE: need to install operating system on laptop with no cd rom or driv
I believe this model of laptop was designed for Windows 95, which can be installed using only floppy disks. That would be just about your only solution. I would not recommend trying to install XP or anything on it, due to the outdated hardware. If it has a PCMCIA Slot on it (most do) you can buy a USB adapter that goes in there. But, as I stated before, I would just install Windows 95 on it (or possibly 98SE) Good Luck!
SOURCE: PC can't read a blank CD
try using a different brand of the blank cd. some computers wont recognize some brands
SOURCE: I have just installed a
If you have installed the chipset driver, you could locate the producer of the CD/DVD ROM, and check if there is drivers to download from their homepage.
You will need a operatingsystem disk or a repair disk to fix it. Insert it in the drive then bootfrom it. You want to get to a dos command prompt (black screen with whitelettering) and type the following commands. Press ENTER after eachcommand.
bootrec.exe /fixmbr
bootrec.exe /fixboot
bootrec.exe /rebuildbcd
Reboot and see if the problem is solved. If not get back to the doscommand prompt and run the check disk utility.Torun the check disk utility you will need a repair disc or a operating systemdisc. Put the disc in the cd drive and boot from it. You want toget to the Dos Command Prompt (Black screen with white letters) and type thefollowing command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
