See above
SOURCE: I was wondeing if I need a anti theft by pass
yes a spare key will be consumed into the installation using part #
556uw $20-$30
or use canmax part but very expensive $100+ no key consumption.
SOURCE: anti theft light came on, car would not start,
the manual says to put the key in the ignition, turn on all the way, but don't start the car and leave for 10 minutes until the theft light stops flashing. turn off all the way and star it up. good luck.
SOURCE: I have a rs1304dp 11
Best advice i can offer is to get the side cutters out and remove htis object ,just look at the amount of problems on this site alone and you will see they always give problems after a while and have to be removed ,the other problem is they stop working when temperatute drops as well ,these things are made in china from inferior micro chips and are just a waste of space and money
SOURCE: how to bypass passlock anti-theft
Hello! You will need a GM Passkey Bypass Module for a Remote Start installation...See photo of an example below...It is a Fortin - Passlock -SL2-GM Passlock Data Bypass Kit for a remote starter...
Cost ranges from $30- $45...Guru.Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
