Canon Pixma MP990 InkJet Printer Logo
A
Anonymous Posted on Aug 04, 2014
Have mp990 using windows 7 printer is not responding through the wi fii have followed instructions for using the wps lan method for the access point push button option but it aleays does not connect t
Having trouble connecting the wifi of the printer with the computer
Level 3:
  • Canon Master 19,187 Answers
  • Posted on Aug 04, 2014
Canon Master
Level 3:
Answers
19187
Questions
0
Helped
4339392
Points
82259
What is your network IP address? You can find the address by using a command prompt and typing IPCONFIG and hit enter.
5 Related Answers
Anonymous
  • 3422 Answers
  • Posted on Aug 05, 2008
SOURCE: Network Setup for Pixma MP970
HI,
the easiest way to do it is to go to the computer with the printer attached, go to control panel, and printers, right click the printer you want to use and click sharing.
click the radial button "share this printer" and give it a meaningful name.
the go to your laptop, go to start, run and type the ipaddress of the computer connected to the printer in the form
\\nnn.nnn.nnn.nnn\ this will bring up all the shared folders and printers available on the computer. right click the printer and choose connect.
the rest of the process will be similar to installing a normal windows printer. it will appear in the windows print menus like any other printer.
of course you will need to leave the main computer powered on, not necessarily logged in, to be able to print from the laptop.
Anonymous
  • 11 Answers
  • Posted on Mar 20, 2009
SOURCE: set up wireless connection canon mp620
I realize that you posted this question over a month ago...but I'll still give you your answer in case anyone else is also experiencing this.
All you need to do is enter in the correct password...the one you gave your router. Which I realize was probably a while back, and you didn't write it down (tisk tisk), so here's how you find out what you typed, way back when.
open up your internet browser (Internet Explorer, Firefox, Safari, ect...). Now in the search bar type in your routers IP address.
mine is: 192.168.2.1
yours might be the same or might be something similar...like: 192.168.1.1
only type that, and include the dots...no www junk.
once you typed it in, hit enter.
and now you should be in your router...then steps hold true for all routers I believe (mines a belkin).
it will ask for a password, most people simply leave theirs the default password, my password was nothing....literally, I just left it blank and clicked 'next'. yours might be 'admin'...a google search should help you find your routers default password.
Ounce you have the routers password, you have access to change a lot of the routers features...including finding out that pesky passphrase that your in search of.
your welcome.
I accept cash & credit. I'll send you the bill. ;)
Anonymous
  • 113 Answers
  • Posted on Jun 02, 2009
SOURCE: canon mp620 -cannot change wi-ficonnection back to USB
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=17406
HERE IS THE SITE FOR YOUR MANUAL .....ALL THE ANSWERS ARE THERE ....GOOD LUCK !
CosmaP
Cosma Papouis
  • 409 Answers
  • Posted on Jul 11, 2009
SOURCE: Windows XP SP3 will not recognize the printer is connected.
It could be the cable, but most likly it is a damaged driver. try uninstalling the printer and all the drivers then reboot and resinstall it. You could also run "sfc /scannow" to see if any system files are damaged.
Anonymous
  • 32281 Answers
  • Posted on May 16, 2011
SOURCE: hello, im trying to install
The Canon is trying to connect to a wireless router or wireless access point which is connected to your computer network. Your Sprint 3g device is a wireless broadband device for Internet connection and cannot connect to the Canon using this device.
You need a wireless card that connects to the wireless router or wireless access point.
Otherwise you can connect to your printer using a printer cable.
Where to find wps pin on canon mx494 printer
Hi Mbali, PIXMA MX494 Wireless Connection SetupSome access points (sometimes referred to as routers or hubs) feature an automatic connection button labelled "WPS" which stands for Wi-Fi Protected Setup.This allows permitted devices such as your PIXMA MX494 to connect to your network without needing to enter a password and it enables a quick and easy method of connecting your devices.This method is by far the easiest way of connecting your PIXMA MX494 so if your access point has a WPS button please select the 'WPS Connection Method' tab below for instructions on connecting using this method.If your router does not support WPS we have provided alternative instructions to get your PIXMA MX494 connected so please select the 'Standard Connection Method' tab below.Back to topWPS Connection Method Standard Connection Method Restore to Factory SettingWPS Connection Method Before we start, there are some conditions that must be met in order to use the WPS push button method:The access point must have a physical WPS push button available. Please check with your device's user guide for details. If the WPS push button is not available please use the instructions on the Standard Connection Method tab.Your network must be using the WPA (Wi-Fi Protected Access) or WPA2 security protocol. Most WPS enabled access points use this protocol.Press the [Setup] button (B) on the printer. Use the arrow buttons (C) to select [Device settings] and press the [OK] button. Use the arrow buttons (C) to select [Wireless LAN setup] and press the [OK] button. The printer will now automatically search for access points supporting the WPS feature. The following message will be displayed on the printer's screen "Press WPS button of the wireless router about 5 sec. and press [OK] on this printer" Press and hold the [WPS] button on your access point for approximately 5 seconds, then release. For exact instructions on starting WPS on your access point, please refer to its user guide. Press the [OK] button on the printer within 2 minutes. Once connected, the following screen will appear. Press the [OK] button to complete the setup.
Thanks
1helpful
2answers
I am trying to connect my canon pixma 452 printer to my samsung tablet. Where is the WPS button ?
  • The access point must have a physical WPS push button available. Please check with your device's user guide for details. If the WPS push button is not available please use the instructions on the Standard Connection Method tab.
  • Your network must be using the WPA (Wi-Fi Protected Access) or WPA2 security protocol. Most WPS enabled access points use this protocol.
Step 1 1. Press the [Setup] button (A) on the printer.
Step 2
1. Select [Wireless LAN setup] and press the [OK] button.
The blue Wi-Fi lamp (A), will light up when the wireless connection is enabled.
Step 3
The display on printer should be as shown below:
(The message will read: "Press WPS button about 5 sec. and press [OK] on the device)"
1. Press and hold the [WPS] button on the access point.
2. Press the [OK] button on the printer within 2 minutes.
The blue Wi-Fi lamp on the printer flashes while searching for or connecting to the access point.
Once connected, the following screen will appear. Press the [OK] button.
If another screen appears, please refer to "troubleshooting" in the user guide.
This concludes the WPS setup procedure.
Please now proceed by installing the software to make the most out of your PIXMA MX474.
  1. If you do not have the installation CD that came with your product, please download the manuals and software.
If the WPS wireless setup is still failing after following this guide, please Contact us for further assistance. 1 888 224 4280
3answers
Can you fix my pixma canon mg3500 printer?
Hi, you need to count the blinks to know what error is.
2answers
HI can print. not connecting wifi
hi, i was unable to attach the manual (pdf file) you can download a user manual from the following site.http://support-in.canon-asia.com/?business
My iphone 5s cannot find my cannon mx452 printer
Please try the following steps to connect the unit to your Wi-Fi router:
1. Press the Setup button on the printer.
2. Use the arrow keys to select Drive Settings and press OK.
3. Select LAN Settings and press OK.
4. Choose Wireless LAN Setup and press OK.
5. If a WPS prompt appears, press the STOP button.
6. Select Standard Setup and press OK.
7. Select your Access Point and press OK. When entering the passphrase, use the Tone or Star (*) key to change character modes.
Once this has been done, insert the CD for the unit into your Windows or Mac OSX computer and perform the installation.
1helpful
Can't connect to wireless network from canon mp499
Steps to Connect Canon MP499 to Wireless Network:
1. Check Wireless Network Settings:
Make sure your wireless network is operational and that you have the correct network name (SSID) and password.
Ensure that your Canon MP499 is within the range of your wireless router.
2. Printer Display:
On the printer's control panel, navigate to the setup menu. Look for a wireless setup option.
3. Run the Wireless Setup Wizard:
Initiate the wireless setup process on the printer. This often involves navigating to the "Wireless LAN Setup" or a similar option.
Select the option to connect to your wireless network.
4. Enter Wi-Fi Credentials:
When prompted, enter your Wi-Fi network name (SSID) and password. Ensure that you enter the correct information.
5. WPS (Wi-Fi Protected Setup):
If your router supports WPS, you can use this method for easy connection.
Press the WPS button on your router.
On the printer, select the WPS option and follow the on-screen instructions.
Greetings,
Antonios
old marine
old marine
ZJ Limited
ZJ Limited
