RTO Paslode 902000 IM250 Ii Cordless 16 Gauge 3/4 2 1/2 Inch Straight Finish Nailer Logo
A
Anonymous Posted on Aug 04, 2014
Why doesnt my nail gun, straight nail finisher wont fire?
Parson's Repair Shop
Level 2:
Sergeant:
  • RTO Expert 284 Answers
  • Posted on Aug 05, 2014
RTO Expert
Level 2:
Sergeant:
Answers
284
Questions
0
Helped
226610
Points
685
I need to have a little more information.
Is the green light flashing on the handle?
Does the fan run when you depress the nose?
The most common problem we see with these is bad / expired fuel - be sure to check the date stamped on the bottom of the fuel cell.
One other basic thing to check:
Bent lower probe - these are very prone to bending & that will prevent it from traveling fully and making the head switch inside.
If you still have problems please post more information about what the tool does / doesn't do and I'll talk you through troubleshooting.
5 Related Answers
Anonymous
  • 195 Answers
  • Posted on Apr 09, 2009
SOURCE: i have paslode finishing nail gun , i cleaned it, not working now
The smoking is normal for a few times after cleaning ,but you might have put to much oil drops in chamber and piston chamber is getting a "vapor lock". Try recleaning with degreaser. Also have you forgotten to set the depth gauge at front of nose.
Please Rate jj505 Thanks
Anonymous
  • 1305 Answers
  • Posted on Jun 21, 2009
SOURCE: CLEANED NAIL GUN EVERY THING SOUNDS OK BUT NOT FIRING CHANGED GAS
Pull the top off and clean the spark plug with a carb cleaner spray.
Check gas canister ...make sure it's not empty..
Do you get a green blinking light on the unit?
K
Anonymous
  • 6 Answers
  • Posted on Aug 16, 2009
SOURCE: paslode shoots a few nails and quits
try a new battery m8 when they have been used fir a while they wear out at the catch and when u fire the nail gun the battery works its way out enuf to stop it making a good contact. Hope this helps.
Anonymous
  • Posted on Sep 14, 2009
SOURCE: When I fire my im250 the firing pin often does not retract
Using a wire "toothbrush" size brush, clean the track in front of the gun where the pin slides - where the nail groove is. **** particles from the nails and the plating from the nails sluffs off fouling the path and causes the pin to stick. After several cleanings of my gun, I noticed that this brushing of the track the firing pin follows keeps it operating for several days without the problem recurring!
Anonymous
  • Posted on Aug 01, 2010
SOURCE: my paslode f 16 nail gun wont fire nails,new gas.
i found this happening to me and i oiled (light oil like 3 in 1) the driver (hammer) in the tip. that way it could retract and drive the next brad.
1helpful
2answers
Dewalt dc618 wont fire
firstly its always better to change both of the bands even if one is broken this always keeps the drive trim.all seems well clean all the contacts ie battery and gun (do not use any cleaning products this will cause grease)just wipe clean with paper towel.
The pin on my Dewalt dc616 cordless finish nail gun is ceasing up. How can i lubricate it? can i spray silicon into the nose of the gun?
Hello, W/D here.
The better way is to disconnect the air line from the gun, and place several drops of light oil in the gun while holding the trigger down. Oil daily. Then, re-connect the hose, and fire a few nails into scrap wood.
Another trick is to spray your nails with WD-40 before you load them into the gun.
Best regards, --W/D--
My paslode f 16 nail gun wont fire nails,new gas. it actually fires but nails wo nt eject.
1helpful
2answers
1helpful
Dewalt cordless nail gun fires but doesn't seem to feed the nails very well, alot of misfires.
Try another brand of nails -- maybe your gun doesn't like those. Also, blow any dirt out of the nail magazine.
Paslode shoots a few nails and quits
1helpful
3answers
When I fire my im250 the firing pin often does not retract fully, so not letting the next nail to progress. I regularly clean and lub the gun and it fires all the time so the problem is not at that end of...
Senco finish nailer not firing nails
firing pin called the driver is probably broken or needs new seals max air pressure 125 psi senco sells repair kits
2answers
I have the above dewalt gun just its battery powered, and it doesnt fire the nails
if the nailer is for 18 guage nail use 18 gauge nail if not 16 guage will jam. if it is not the problem is the profile return asyy may jam in side.
Top RTO Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a RTO Tool and Hardware - Other Expert? Answer questions, earn points and help others
