It will not charge. I even bought 2 new bats. Not sure whats going on.
Since you've already tried different batteries, you have a couple of other options...
Here's the PDF manual for your camera, if you need it: http://us.sanyo.com/dynamic/extranet/servicers/VPCT1495.pdf
(Page 16 contains info about charging the camera)
SOURCE: Battery Question?
hi usually they sugest to charge for between 12 and 16 hours.
It probably wont take that long thought but wont matter how long you charge for.
But remember to let the battery go totally flat on a monthly basis and recharge with full charge if you do this every month or so it will prolong the life of your battery as it does them no good just topping the charge up remember to do this and you should have no problems with the batt.
This also applys to mobile phones and anything that has rechargable battery
SOURCE: Help!! Sanyo VPC-E760 Digital Camera driver for Mac OSX
My Sanyo S6 is showing System error. What I do?
the driver is not separately available for Sanyo VPC-E760
SOURCE: Lens Errors 17 & 27 on Sanyo VPC-E760
My camera was showing lens error 12&25 and then shutting off. I tried gently trying to twist and pull the furthest out part of the lens and it popped back into place easily. It made a noise when it did this, and then i turned the camera off, and the lens went back in!! Completely fixed now!!
SOURCE: The battery is fully charged - wont turn on
Hello
Thank you for using FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Anything is fixable but it is more "is it cost effective"
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
