Need to transfer photos that have text to flash drive . It will transfer picture but no text Help!
Windows Explorer is pre-installed in Windows computer. In other words, you don't need to download or install any 3rd-party software to accomplish how to transfer photos from iPhone to USB stick. Within a few clicks, you are able to transfer iPhone photos to USB flash drive. Now learn how by the following steps.
1. Plug USB flash drive and iPhone to computer. iPhone will receive a prompt to approve it. Approve it and iPhone will be automatically detected by computer.
2. Open Windows Explorer and head to "iPhone > Internal Storage > DCIM". A list of photos on iPhone will show up.
3. Hold "Ctrl" and select photos you would like to transfer to USB stick and press "Ctrl + C".
4. Create a new folder in USB drive or find a folder, then press "Ctrl + V" to transfer iPhone photos to USB flash drive.
For more info: https://www.leawo.org/tutorial/how-to-transfer-photos-from-iphone-to-usb-flash-drive-1361.html?=1400
If the text is actually in the photo, copying the photo to a new location should not lose the text.
SOURCE: Can't find flash drive on
Try removing the USB drives from the Device Manager, then power down, plug in the flash drive and power backup again.
Win should find the drive and reinstall drivers and recognize the drive again.
Despite improvements in the behavior of Widows, it is also still advisable to 'turn off' a removable drive before unplugging it.
If you system is pretty much standard, you should find the drive symbol with an arrow indicating 'remove' on your task bar to the right.
Left-lick on that symbol and it will bring up a short menu of any removable drives and then just click on the one you want to pull.
SOURCE: I have a Innova photo
This photo frame will only support jpeg files. Other formats can't be displayed as show up as a red x. Also, the picture is 800x600 so larger formated files may not display correctly either. Remove the SD card and look at it using your PC. Check that all the files are .jpg - if not either replace or reformat them to be jpg and it should work fine.
SOURCE: I bought last year Mr. Christmas Digital Photo
Try a different flash-drive, preferably one with a _smaller_ capacity.
Did the item come with a one-year warranty? If so, exercise the warranty, and get a replacement.
SOURCE: I am trying to transfer photos from my PC to a USB
If you are logged in as any other user,then the administrator has set up restrictions on the control.So to send photos and other data log in as administrator or ask the administrator to give full control to others user.
Thanks.......
SOURCE: transfer photos
I've never heard of that. Try copying the picture files to an external drive or a usb flash drive. Then you can put them anywhere you like on another computer requardless of whether it's 32bit or 64 bit.
