Once you plug in the MP3 player, open Windows Media Player and you should see it listed as a device. Right-click the device in the left-hand column of the Windows Media Player and click 'Set Up Sync'. Put a check in the 'Sync this device automatically' checkbox and then add one of your existing playlists that are in the list on the left side to the right side by selecting the list and clicking the 'Add' button, located between the two lists. If you don't have a playlist, you'll need to create one.
Once you have all the songs you want to add to your mp3 player added to your playlist, you can then select the device again, and click the 'Sync' tab at the upper, right-hand corner of your Windows Media Player and then click 'Start Sync' to sync the playlist with your mp3 player.
Any songs you want to add or remove from your device, you simply add or remove them from your playlist and then sync it again.
RIGHT CLICK ON MY COMPUTER SELECT PROPERTIES
SELECT HARDWARE TAB
SELECT DEVICE MANAGER
DOUBLE CLICK ON DVD/CD ROM DRIVES
DOUBLE CLICK ON YOUR DVD DRIVER
CHECK IT IS WORKING PROPERLY
IF COMPUTER INDICATES IT WORKS PROPERLY YOU CAN DO THIS:
Double-click the device category to display all devices in that category.
Right-click your device, and then click Properties.
On the General tab, read the Device status message.
Note
To open Device Manager, click Start, click
Control Panel, click Performance and Maintenance, and then click
System. In the System Properties dialog box, click the Hardware
tab, and then click Device Manager.
If Device status reports a problem with your device, click the
Troubleshoot button under Device Status for suggestions on how to
solve the problem.
If your device is not listed in Device Manager, it is not recognized
by your computer. You need to install a new device driver manually.
To install a driver manually
Click Next, and wait for Windows to search for Plug
and Play hardware. Most newer hardware is Plug and Play, so you will rarely
need to go beyond this step.
If no Plug and Play hardware is found, a list of hardware types appears.
Click Add a new hardware device, and then click Next.
Click Install the hardware that I manually select from a list, and
then click Next.
In the Common hardware types list, click the appropriate hardware
category, and then click Next.
In the Manufacturers list, click the manufacturer of your hardware,
and then in the Models list, click the model name.
Or, click
Have Disk if you have an updated or third-party driver to install for
your hardware.
Click Next, and then follow the instructions on the screen to
complete the installation.
Note
To open the Add Hardware Wizard, click Start, click
Control Panel, and then click Printers and Other Hardware. Under
See Also, click Add Hardware.
if this information was helpfull to you please vote for me and write a comment for me.
i have nokia n73 and i want smart movie 4.00 license key.my serial number is: 355718024452011 kindally plz plz plz send me my license number immedetly. my email address is [email protected]
