Canon PowerShot SX130 IS Digital Camera Logo
A
Anonymous Posted on Aug 04, 2014
Battery cover door replace - Canon PowerShot SX130 IS Digital Camera
Ken Williams
Level 2:
Sergeant:
  • Expert 263 Answers
  • Posted on Aug 22, 2014
Ken Williams
Expert
Level 2:
Sergeant:
Answers
263
Questions
Helped
132914
Points
582
Canon will send you a new one for free or minimal cost. There is a pin that acts as a hinge. push it out from the side with a paperclip or very small screwdiver or punch. reinstall the new door in reverse careful of the spring. Some cameras, there's a screw holding the door on, in this case the new door will include the hinge.
Where can I buy a replacement battery cover door for a Nikon Coolpix s7c please?
Hello again
There is one repair place that lists 700 different battery doors, but your is listed and out of stock. AliExpress also lists doors and sometimes they end up on eBay. Your best bet is Nikon direct.
https://www.google.com/search?q=replacement+battery+cover+door+for+a+Nikon+Coolpix+s7c
Kodak CX6200 Battery Door Replacement
Link to purchase of battery door with instructions
Batteries dead on my Sentry E163026 safe dont know what to do
A1 locksmith advised me to To install batteries, remove cover between knob and keypad.Unlock door with the override key provided in the plastic bag attached to the owner's manual, and open the door using the knob. Remove battery cover located on the inside back of the door by sliding to the right. Insert the four batteries as indicated. Replace the battery cover.
3helpful
Need to replace battery door.
i have not replaced the battery door but have disassembled an S5000 following the service manual
it looks like once you complete the first step 'Removing the R CABINET ASSY' you can withdraw the hinge pin and replace the battery cover without any more disassembly [see attached image]
2helpful
4answers
How to change batteries on ku916aa
1. There should be a cover on the bottom with a release lip the batteries are here to replace. this is located right below the on/off button.
1helpful
Battery cover door won't stay on
you should please seek the companies tech support. sometimes the should replace the phone .this is a manufacturing defect.
2answers
Battery door
Bushnell Repair Center
8500 Marshall Drive
Lenexa, KS 66214
Canon digital camera
Same problem here with broken battery cover door! Called Polaroid and NO they do not have these parts to replace....if the camera was under warranty Polaroid would have replaced the entire camera.....soooooo when you find out any info as to where to get the battery door list the info! Thanks! & good luck too!
How to replace battery door?
I just replaced my battery door. You have to take every screw out of the camera. I used a philips eye glass screw driver. Then, pull the front and back covers apart carefully, its only plastic. There is a pin that holds the door to the rear cover. If you push the battery door button back and fourth the pin will start to show out the side of the camera. I pulled it out once it showed with small pair of needle nose pliers. Just reverse the procedure to install the new door.
1helpful
4answers
Replacement Battery Cover Assembly
If you're handy, you can replace it in about 3 minutes. Don't attempt it unless you're willing to risk tearing a thin flexible circuit under the rear cover. Looking at the camera from the rear, remove the screws on the right hand side ( 2 ? ) then the screws across the bottom - open the card door, remove the card, and wedge a knife blade between the front and rear cover halves - the card door will be loose with an attached spring coming free. No need to remove the rear housing completely, just enough to expose the tracks for the battery cover hinge. Remove the old door, noting the position of the opening spring at the hinge, by angling one hinge out first. Insert the new battery cover and the card door in reverse order.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
