troubleshootmyvehicle.com > Nissan > 1.8L
Feb 12, 2013 - What Tools Do I Need to Test the COP Coils. ... coils (most commonly known as the COP ignition coils), on your 1.8L Nissan Sentra is pretty easy. ... When one COP ignition coil fails... that cylinder goes 'dead' due to a lack of Spark and is said to be misfiring. .... 2000, 2001, 2002, 2003, 2004, 2005, 2006 ...
Jan 17, 2013 - Checking for Spark With a Spark Tester. ... Your 1.8L Nissan will either have a distributor-type ignition system or the more modern COP ... A BAD fuel pumpwill cause your 1.8L Nissan Sentra to Crank but Not Start... since the ... Still, the other method that I've used to test for a lack of fuel... is spraying starting ...
www.b15sentra.net > ... > Technical Discussion
Nov 4, 2008 - 15 posts - ‎3 authors
I have never had a problem with the car before (02 Sentra 1.8/auto), so I had no need to post ... Originally Posted by Black B15 ... Join Date: Jun 2005 ... Can you see if the coilpacks are getting spark & work back from there?
how many spark plugs do i need ? - Nissan Sentra ...
Mar 19, 2010
Spark Plug Replacement - 2002 GXE 1.8L - Nissan ...
Oct 12, 2009
1.8s starting problems - Nissan Sentra Forum - B15 ...
Jun 23, 2009
No start on 1.8L 02 GXE - Nissan Sentra Forum - B15 ...
Apr 11, 2009
More results from www.b15sentra.net
