Warn Industries Warn 64851 Atv Winch Mini Rocker Switch Logo
A
Anonymous Posted on Aug 03, 2014
Warn winch troubleshooting
Winch payed out, however will not retract
Len Burgess
Level 1:
New Friend:
  • Contributor 16 Answers
  • Posted on Aug 12, 2014
Len Burgess
Contributor
Level 1:
New Friend:
Answers
16
Questions
Helped
5484
Points
25
It sounds like your solenoid is not reversing the polarity , which will require a new winch solenoid. Before replacing the solenoid, check your switch. It might have one contact no good. Switch the wires around and try to retract winch by paying out.
Warn vr 12,000 everything working but when i try to winch in its like the clutch isn't engaged
Cause:
  • There is grease, dirt or rust between the outside of the sliding ring gear and the inside of the gear housing.
Possible Solution:
  • Clean the surfaces of the sliding ring gear and gear housing.
  • Coat the surfaces lightly with oil. Do not grease.
Winch is stuck in freespool
Customer Reviews: Warn 89040 Vantage 4000 Winch ...
www.amazon.com/Warn-89040-Vantage-4000.../B00...
Amazon.com, Inc.Find helpful customer reviews and review ratings for Warn 89040 Vantage 4000 ... I love using the handlebar remotes while plowing snow, but when you're stuck in ....Works great the only complaint is the free spool knob doesn't engage and ...
Amazon.com: Warn 89040 Vantage 4000 Winch - 4000 lb .
1helpful
How can I fix the remote control for a XT 30 Warn winch ?
looks like it's hard to get..
why don't u try online
some websites deal in it real time.. along with solutions to problems how to repair fix service nd all
How do i rewire a warn 12v 8000lb winch
There are lots of links on the internet to wiring diagrams; just make sure they match the winch you have
warn 8000 lb winch wiring diagram Google Search
1helpful
2answers
My winch don't move it all?
if you can use the winch manually by pressing buttons on the winch then the problem will be in either the remote unit(Battery in back to front) or the receiver in the winch
How do I check on the winch I recently purchased
There should be a black connection on the winch. This is ground or -. There is a red. it is +. Find a battery and jumper cable, connect on all but one terminal. Tlouch and the motor should spin.
This proves the motor runs. Then connect the control, and this will prove the control.works (cables connected firmly and the control is used to run forward and backward.
Warn winch 2006 Suzuki Eiger Winch will retract cable but will not extend cable
Use a test light at the contactor to see if the switch and wiring are good.If you see an input from the switch up to the contactor,make sure the connections are all clean on the control input terminals at the contactor.(The contactor is the device that changes the polarity of 12V to the winch to extend or retract-essentially a double throw double pole relay).
Can not pull winch cable out had to take cover off
The clutch knob on the side needs to be loosened up. Rotate this and the shaft will be free to pull the cable out.
Top Warn Industries Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you a Warn Industries Boating Expert? Answer questions, earn points and help others
