Dishwashers Logo
S
Steve Desino Posted on Aug 04, 2014
Reset code pld4555rfc3
victorfuentes
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 04, 2014
victorfuentes
Contributor
Level 1:
Answers
Questions
0
Helped
272
Points
0
Hola la manera de borrar los codigos en lavadora balay ts50100, poner selector en 0 pulsar boton de encendido y manteniendolo pulsado girar selector hacia la izquierda un toque sino se borra sin soltar el boton poner selector en 0 y repetir lo anterior hasta que se borre el error.
Pld4555rfc3
Hello ddux97 - Here are a few simple troubleshooting tips that may help you resolve this issue:
· Do you have hard water? Hard water is the primary reason to cause soap residue. Water hardness can be determined by the local water supply company, water treatment company or via a water hardness test kit, which can be found at local part distributors or hardware stores. Some kind of water softening is recommended, in areas where the water hardness is 12 grains or higher. For very hard water a home water softening system would be recommended.
· Will the upper spray arm rotate freely? If it does not, then there isn't enough water being pumped to the spray arm or the full flow of water is not making it to the upper spray arm. Remove or replace the spray arm assemblies since it is possibly damaged.
· Confirm that the drain hose is strapped up properly under the sink to prevent the water from siphoning out during the cycle.
· Dishwashers require the water inside the unit tank to be 120F to perform properly. Best way to ensure this happens is to run the sink faucet until the water comes out hot before the dishwasher is turned on. This will ensure that hot, 120F water goes directly into the dishwasher when it starts to fill. When checking dishwashing detergent boxes and with detergent manufacturers, the compounds in the detergent need water temperatures to be between 125F - 140F to dissolve in the dishwasher. The water pressure should be 20-120 psi (pounds per square inch). If it is too low, I recommend reaching out to a plumber to further assist you.
· Rinse aid dispenser should be checked and filled about once a month depending on the number of washes you do in a month since this will cause cloudy dishes and soap residue.
If these basic troubleshooting tips prove ineffective, then at this point, I would recommend having a service technician to diagnose the problem before investing in unnecessary parts.
Pld4555rfc3 dishwasher...switches to china
Hi kelli kelly - From what you have described if the dishwasher switches to china mode, then there seems to be a communication problem with the main control board or wiring harness. I strongly suggest contacting a professional to move forward accurately and to properly diagnose the unit.
6helpful
4answers
What is the reset code of nokia
What is Nokia Phone model?You can reset the Phone easily using the master reset code.you can get the master reset code for old NOKIA DCT phones at Theunlockspot.com and reset from security lock.You can also get the master reset code for Alcatel Old Phones here..Try default code for Nokia Phones 1234 or 0000 if these codes not work means get mater reset code and reset it.
10helpful
3answers
I can't remember my security code. How can i reset it?
My nokia 2700c model.my problem I don't know phone reset code.please halpe me show my phone reset code
Sep 14, 2011 • Cell Phones
5helpful
4answers
How do i unlock my fone . iforgoten the code
To get the Phone reset from security lock get the Default code from service provider........
Aug 31, 2011 • Cell Phones
2helpful
I cannot remember the phone lock code i put on my phone
What is Phone brand and model?
you can reset the Phone using the master reset code,you can get the master reset code from here
Classicunlocking.com and reset it,i have reset my phone nokia 6600 from security lock using the master reset code.You can get the master reset code for Nokia and Alcatel Phone there,Before Getting the master reset code you try some Default code 1234 or 0000 for Nokia and reset it.If not work get the master reset code there.
Found an oval rubber gasket in bottom of 4000 series AquaSurge with speedclean dishwasher model PLD4555RFC3. Look to go inside dishwasher but cannot locate where
Hello, Thank You for using FixYa. I will be helping you today.Here is a parts break down of your model CLICK HERE See if you can locate it im not aware of an oval gasket.
Thank You and please rate my answer if it was helpful..
The button is locked and it wont unlock the air dry setting, so i cant wash my load
Try resetting the breaker, If that does not work you would either have a control board problem or the control panel toucpad itself. Here is a link for a breakdown of the unit, and Part ordering info:
http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Dishwasher-Parts/Model-PLD4555RFC3/1428/0130000/R0809006/00001?blt=06&prst=&shdMod=
Sorry I did not have the part at my store myself to help:
http://stores.ebay.com/Discount-Appliance-Parts
5helpful
2answers
Er...error code
FREE FIX!! Before you do anything else try this....
Blinking display with "ER S" on this model is a "keypad error" NOT a control board error. It occurrs when a button on the keypad is "stuck" for more than a minute most likely from being corroded - which can happen when the steam accumulates on the underside of the counter and drops down onto keypad (an apparent design flaw which frigidaire will do nothing about) - all the techs I've talked to recommend replaceing the entire plastic keypad assembly (oem part cost $125 at my local store). But they sell just the switch that is glued into the assembly for 16$ at www.repairclinic.com and it is a thin plastic film with electronic circuits running through it. Before you buy it though, turn power off at breaker, then try gently prying the keypad switch cover (the strip with the buttons on it) off of the top of the door panel (It is stuck down with a double sided clear tacky strip - I did it with a thin butter knife) and cleaning off any corrosion on underside of strip and on switch. Gently replace the keypad cover strip and press down around the edges gently. Then turning power back on to machine and see if that fixes it - worked for me - FREE!!! Worth trying before you call out a tech
Brand New overflows PLD4555RFC3
If this is new construction or a new disposal, check the hose that drains from the dishwasher to the disposal - the installer may have forgotten to remove the plug when they connected the hose.
Top Frigidaire Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
