Garden Logo
A
Anonymous Posted on Aug 03, 2014
Why wont my john deere d140 move when I ngage the double foot pedal
My John deere d140 lawn tractor runs fine and the pto engages fine but it will not move when I step on the pedal. Why doesn't the transmission engage?
A
Anonymous
There's a transmission disengagement lever at the rear of the tractor over the axle. This lever is pulled out to disengage the transmission in order to move/tow the tractor if the engine isn't running. If the lever has been pulled out, the hydrostatic transmission will not operate. Locate the lever and try to push it in. If the lever is pushed in, the transmission is now engaged, and the foot pedals should activate the transmission forward and reverse.
Tim Hofstetter
Level 3:
Genius:
  • Master 1,406 Answers
  • Posted on Aug 04, 2014
Tim Hofstetter
Master
Level 3:
Genius:
Answers
1406
Questions
0
Helped
378828
Points
4295
The drive belt may be broken, or it may have slipped off a pulley.
5 Related Answers
Anonymous
  • 11 Answers
  • Posted on Mar 11, 2009
SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Anonymous
  • 61 Answers
  • Posted on Sep 07, 2009
SOURCE: pto clutch will not engage
ck fuses, and switch, for 12 volts
nova2nv
Bill Linda Rivard
  • 197 Answers
  • Posted on Nov 14, 2009
SOURCE: Fuse blows when engage blade
The electro-magnetic coil side of your PTO is shorted out.On the 318 it is very easy to replace,just under front screen.
Anonymous
  • Posted on Jan 21, 2010
SOURCE: john deere 425 lawn tractor. it wont start but it
My John Deere did the same thing. Turned out to be the emergency brake sensor.
Anonymous
  • 1627 Answers
  • Posted on Jul 29, 2010
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
John Deere D140 PTO clutch tries to engage but fails. Why?
Try the following test. For safety purposes remove spark plugs. Now with engine off and key in run position turn PTO on. You should hear the clutch engage (clunk). Grab both sides of the clutch pulley and try to rotate the pulley. If the clutch is properly engaged you will not be able to rotate the clutch pulley without turning the engine.
John deere d140 lawn mower shoots of when i ingage the blades
Here's the link and I'm sure you will get the solution of your problem.
JOHN DEERE D140 SERVICE REPAIR MANUAL
GOOD MORNING, I HAVE A D140 JOHN DEERE LAWN MOW,IT RUN WELL WHEN NOT MOWING BUT WHEN ENGAGED IT SLOW DOWN AS THOUGH IT HAS TO CATCH IT'S BREATH LESS THAN THREE YEARS OLD
Make sure there isn't anything binding the deck belt or blades. Check the spindles for free movenent. If all that is good then it might be the linkage that is supposed to adjust the throttle when the engine is under load or it might be a carb issue...especially if you run ethanol gas in it.
D140 Belt won't engage. Replaced Switch. Still doesn't work. Any Suggestions?
does it have electric PTO ? if it does then you should be able to hear it click with ignition on and engaging pto switch if it does not then you have to look for a bad safety switch located under seat and brake pedal try unplugging pto clutch and putting 12 volts dc to one wire and grounding the other wire if it clicks its ok if it does not then safety switches are the probable cause witch is causing an open circuit.
John deere d140 ont move
there is a small handle on the back of most riders allowing you to free wheel the machine. If you can push your machine freely now then push the handle in and it should drive
Why wont my john deere d140 move when I engage the double foot pedal
check and see how much fluid in trans mission and change hydrostatic transmission filter
X595 john deere pto wont kick in
These John Deere Garden Tractors have a RIO (Reverse Implement Option) on the PTO. If your PTO is engaged and you back up, the PTO will automatically stop. To reset it, depress your PTO engagement switch to the OFF position. Take your foot off the reverse pedal. Pull up on the PTO engagement switch. The PTO should restart. To use the RIO feature, pull up on the PTO switch for a second or two just before you step on the reverse hydrostatic pedal. The yellow RIO indicator light should come on your dashboard and you can now back up with the PTO still running. Works great for snow blowing when I don't want to keep resetting my electric PTO clutch to keep restarting my snow blower.
If your PTO will not restart, you may have a PTO switch starting to fail, or a likely logic problem in your electric PTO control module, or one of your forward/reverse indicator switches, which is linked to your PTO control module along with the overtemp circuit, is stuck/faulty.
Top John Deere Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a John Deere Garden Expert? Answer questions, earn points and help others
