HOW DO I PROGRAM THE PHILIPS REMOTE CL035A TO THE DIGITAL STREAM CONVERTOR BOX.
SOURCE: Universal remote codes for Philco digital to analog converter box
http://www.remotecodelist.com/remotes/
SOURCE: Trouble programming Universal Remote to a DTV Converter Box...
Not a complete solution, but, around the last page (pg. 14) of your converter box manual there are codes listed for universal remotes. I happen to have a Philips remote that is listed. My code to control my dtv box is 0354. It appears that they have all codes listed for all Radioshack model universal remotes. I would suggest getting a Radioshack remote for Your "Digital Stream" (Radioshack) dtv box...
SOURCE: i have a philips universal cl035a remote.i need
In the manual it say's that what you need to do is hold the code search button untill it stay's steady then press the function button (TV, cable or whatever) for the device you need to program before doing this though turn the TV or whatever on first. Then go to the chanel select up or + button and continue to press it until it changes channel if you over shoot it you can press the - or channel down button.
When you are were you want to be quickly press the mute button and release ( warning do not hold the mute button just press it quickly and release.) This will set the remote to the corect code.
SOURCE: I need Philips CL035A codes list for toshiba tv
I believe this is your remote. it's listed as pm435s
http://www.p4c.philips.com/files/u/us2-pm435s/us2-pm435s_dfu_eng.pdf
these are the codes for toshiba
0517, 0419, 0512, 0613, 0719, 0112, 0506, 0111, 0618, 0627, 0437, 0041, 0094, 0802, 0111, 0313, 0715
