SOURCE: Parrot CK3000 Evolution
after a reset try to push the parrot in pairing with your phone.< for any G3 phone the below should work. The menu could be differnet on yours this is for a nokia G3 phone. Object Push: * From your phone go to MENU / COMMUNIC. / CONTACTS * Select the desired contact to send * Go to OPTIONS / SEND BUSINESS CARD / VIA BLUETOOTH / ALL CONTACT DATA * Phone will search for available bluetooth devices * Select from the list Parrot Product and press SELECT * wait until the contact is transferred. After contact is sent, it is neccessary to register "Contact's Name"
SOURCE: Blackberry 8110 contact transferring to Parrot CK3000
make sure you are just transferring contacts with phone numbers and nothing else (email addresses et. etc. ) also make sure the area code is included(even on local ones) take the parrot's battery out for about three minutes, do the same to the blackberry) should fix....enjoy
SOURCE: fitting hands free car kit Parrot CK3000 Evolution
Just make a look:
http://www.parrot.com/uk/support/onlinehelpguides/parrotck3000evolution
SOURCE: Parrot CK3000 evolution wont conect to my nokia
Try sending an MP3 to the Parrot kit in your Triton. I couldn't even
get the BT in my 380 to ask for the BT password numbers but found out to
try sending an MP3, which will fail by the way, and it asked for the
password finally.
There was an
error in my case, but then the phone asked to connect to the Parrot
again and the pairing worked.
There is an issue with newer Nokia
phones, something I will be thinking about next phone upgrade.
