Why did the Kenmore dryer Stopped in the middle of a cycle and will not restart. It will not come on. We checked the circuit breaker is was fine. What should we do to help fix this problem?
SOURCE: Maytag Electric Dryer Stopped Working
Check spring tab behind door switch-if it's bent/out of adjustment, circuit will act like door is always open.
To confirm this, open door, set dryer to active setting, and hold in door switch; if it comes on, then it's either the spring tab, or the switch is malfunctioning
SOURCE: Kenmore 90 series model 110 60902990
There is a thermal fuse in the back of the dryer, its usually white plastic, usually with 2 lite blue wires going to it.its probally blown...you can check it with an ohm meter......but if it is blown make sure you check the vent hose to make sure it aint kinked off that usually causes them to blow. if it aint that, be sure to make sure the heating element aint shorted to the heater box.or the thermostats aint stuck....the thermal is a safety feature and something caused it to blow
SOURCE: kenmore dryer will not dry completelt in even heat cycle
This video will help you to determined what you need,
copy n paste
http://www.youtube.com/watch?v=HRKIU4LiS20&feature=related
for parts n prices
http://www.partselect.com/AppliancePartList.aspx?Brand=Kenmore&Appliance=Dryer&ModelNum=&Type=Electrical%20Parts,%20%20No%20Heating%20Elements&MinSize=U&MaxSize=U&Electrical=Y&Metal=U&Plastic=U&OneColor=U&PageSize=15&FirstPart=1
Was this helpful?
SOURCE: My dryer just stopped working in the middle of
Is the motor still running...did you check that?
If the motor is running then sounds like you have a broken belt or a belt that has slipped off the pulley of the motor
SOURCE: Maytag dryer stopped working (model LDE9334ACE -
Check your timer switch, that would cause you light not to work.
Also check the bulb, it may be burned out.
I hope this helps
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
