Toyota 1984 hilux. been sitting awhile, 6 months. indicators and horn used to go. vehicle starts premo. now no horn,indicators and hazard lights. reverse,brake and park lights work. checked fuses and they're fine. at wits end. bulbs are fine. have Haynes repair manual but cant make heads or tails of wiring diagram.
SOURCE: Tail lights/front parking lights don't work.
Please use this link:
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c152800c4326
Good luck..
SOURCE: 2001 dodge neon tail lights inop
looking at your schematics and , you say tail lights don't work , you didn't mention if front parking lights and license plate lights are working , they all come from the same source , a black /yellow wire , a good clue if front work and rear don't , please advise .if fronts work then you have a open circuit somewhere between junction S118 (near breakout for left headlamp) and rear sockets.
SOURCE: Left rear brake light stopped working but bulb and fuses are OK.
These are Dual Function Bulbs. They control the Parking Lights and the Brake Lights. This Bulb is Burnt out on the Brake Coil inside the Bulb. I have actually seen Bulbs that were Bad But you could not Tell by jast looking at them. It should be fine with a New Bulb. Please Rate My Response! Thanks!
SOURCE: no electric start
Can you tell me what kind of machine this is??
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: my brake lights wont work
Just had a similar problem. Brake (stop) lights and horn didn't work. Couldn't find mention of stop lights in fuse chart. Found horn fuse to be slot 21 in the engine fuse block (not the fuse block in car interior). Replaced 15A fuse and all now ok.
