Try picking up the drawer and tilt it up as your putting it in,push it far enough and the wheels or what have you will drop in.Or try the opposite.
Len
TAKE OFF KICKPLATE ON BOTTOM OF UNIT. UNHOOK WATER LINE FROM QUICK CONNECT UNDERNEATH. ON TOP OF FRIDGE THERE IS A COVER OVER THE DOOR BRACKET. REMOVE THAT COVER. THEN REMOVE THE 2 OR 3 SCREWS HOLDING BRACKET TO TOP OF FRIDGE. THEY USUALLY ARE 5/16TH SCREWS.MAKE SURE THE HAVE DOOR SHUT OR SOMEONE HOLDING THE DOOR WHEN DOING THIS. AFTER REVING SCREWS AND BRACKET LIFT DOOR UP OFF BOTTOM HINGE AND WATER LINE FROM DOOR WILL COME OUT WITH IT.
remove the top plastic cover that hides the freezer bracket. Remove the screws that hold it on. pick the door up off the bottom bracket. if it has a water dis unhook hose. do the same to the fridge door
There are two (or three) screws that hold the hinge bracket on, top and bottom. You will likely have to remove the freezer door to be able to get to the top of refrig door, if so equipped. Dodnt remove the bottom bracket as it is not necessary ... work from the top down.
Good day,
Just go to your local appliance parts house. They will have the shims you will need. Remove the top bracket, open the door slightly, and lift the door off. Install the number of shims necessary, and reinstall.
If it has a cam style bracket that helps close the door, replace it as well. It just bolts on, once the door is removed.
remove freezer door. now remove hinge on top of bottom door. lift bottom door off. now place a washer on bottom hinge and re install everything. this should solve your problem.
Good day, First. Save and mark all shims and bushings you remove in the process. As well remove all food from both doors. 1. Remove bracket from top of the refrigerator with the door closed. Once removed, open top door with 2 hands about 1 foot. Lift off. 2. Remove center bracket and remove as in step one. 3. The bottom bracket can be removed and mounted on the other side, reversing it's orientation. (pin sticking up). 4. remove both handles and remount on other side. There are many plugs that must be removed, to uncover new screw holes. Some may be covered with emblems, but can be pried out with a small screw driver. 5. Reinstall in reverse order checking for alignment as you proceed. 6. Push in all removable plugs when complete.
Make sure all items are removed from both doors, and machine should be shut off.
1. Remove top bracket with the freezer door still shut. With both hands, open freezer door about 1 foot, and lift off. All thru this process keep track of all shims and washers and their location. 2. Remove center bracket holding main door and remove using the same process as with the freezer door. 3. Remove bracket from the bottom and reverse to the other side. There will be a lot of press in buttons to be removed by prying them out with a small screw driver. 4. Reinstall in reverse order, making sure all shims and washers go back where they came from. As well, Tighten screws while making sure the door is in alignment at the same time. 5. Remove both door handles and reinstall. Some screws may be hidden by a cover that will have to be pried away first.
My dad's freezer handle is loose, model ABB2224DEW. Went to partselect.com and located drawing of freezer door parts. Found a link to a "do-it-yourselfer" that describes removal and replacement of the handle. Hopefully this helps.
Replacement of freezer door handle. 1. Removed freezer door handle. First I read the freezer door handle removal instructions in the Amana refrigerator user guide. Removing the handle requires inserting a plastic card at least 1.5 inches under the left end of the right side of the handle so it releases the butterfly clip latch on the freezer door. Next I pulled the right side of the handle to lift it away from the freezer door. Then still holding the handle away from the door, at the spot that is 1.5 inches from the inside of the right side of the handle, I held the plastic card vertically and slid one corner of it between the handle and the freezer door and worked the card down until it released the butterfly clip latch. Keeping the card at the same space under the handle so the latch was released, I then turned the card to the left until it was horizontal and was lifting the left end of the right door handle away from the freezer door. I then slid the handle across the card to the left until it cleared both door butterfly clip latches and it lifted off the door. 2. Installed freezer door handle. First I read the freezer door handle installation instructions in the Amana refrigerator user guide. The handle is curved on one edge and must be installed the curved side down. Correctly installed, the outside ends of the handle curve upward and the handle curve is down so it looks like a frowning mouth. Next holding the handle curved edge down, I turned it up so I could see the brackets and held it against the door. I lined up the handle brackets slightly to the left of the butterfly clips on the freezer door. Next I turned the handle with the brackets against the freezer door and slid it slightly to the right until the left side of the handle held onto the door butterfly clip by itself but was not latched. Then I lined up the right handle bracket with the right freezer door butterfly clip and carefully slid the whole handle to the right until I heard the left butterfly clip latch click. Next I slid the handle back slightly left once more and then slid it back to the right until I heard the right butterfly clip latch click.
Parts Used:HANDLE, DOOR (WHT)Level of difficulty:
Difficult
Time to do repair:
30 - 60 mins
1.you will need to reach the top of the fridge. there is a cover there that will need to be removed. there might be a screw in the middle of it. if not than it just pops off.
2.you will need to remove those screws that hold that bracket on. after this you will be able to remove the freezer door. just open it and lift up the door will come off.
3.the bracket that the freezer came off of in the middle of the fridge you will need to remove these screws. After you have removed these screws the fridge door will come off. just open the door and lift up.
if you need to remove the lower bracket at the bottom of the fridge than you will need to remove the plastic cover and take the screws out of the bracket and the bracket will come off.
please do not forget to rate and comment about your experience today.
