How do you clear the "call your technical rep" on the display?
SOURCE: MINOLTA CF3102 PRINTER
This code is related to fusing pressure, which could mean fusing unit malfunction.
Put paper clip through a hole under LED cleaning pads inside the front door to reset.
Caution!!! Not recommend for the end user to reset fusing related codes since it could result in a fire.
SOURCE: Code : M3
I think that is for waste toner bottle it is full just clean or change it .and reset all counters .MIAN AKHLAQ
SOURCE: minolta Ep4000 show CodeM2
Set the copier into Tech. Rep. mode by pressing the following keys in this order : utilty meter count stop 0 stop 1 then from the menu select counter then select Maintenance select the conter then enter anew value from the 10-Key pad
SOURCE: I have a Minolta cf3102 color copier. I pulled out
on the duplex unit is located on wright side .open the first outer door looks like 2 door in one .if you do not see any paper look for black actuator .in the center make sure it's not hanging up.
good lock
SOURCE: minolta EP 2050 copier
transfer crona is lekage change the tranasfer corona ano clear the code error ce200
