Screen not coming on, power button is flickering fast. Is this a power issue externally? Or is this something internal?
Which power button is flickering (your computer, or your monitor).
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
SOURCE: Monitor flickering and adjustment buttons locked
If the refresh rate is not properly set the monitor may have a wavy or an appearance that lines are going down ... This may also cause a flickering affect.
Distorted or skewed image on monitor.
Issue:
Cause:
This issue can occur from any of the below possibilities.
Solution:
Windows Issue
If your monitor has a proper display until it gets into Windows 3.x, Windows 95, Windows 98, Windows NT, Windows 2000, Windows ME, or Windows XP please see document CH000121 for software or setting related issues.
Loose or defective cable
You may receive a distorted image when the cable is loose or defective. Disconnect the video cable going from the back of the computer and verify that no pins are bent, burnt or broken. Once verified re-connect the monitor cable.
Refresh rate issue
If the refresh rate is not properly set the monitor may have a wavy or an appearance that lines are going down or across the monitor slowly or fast. This may also cause a flickering affect.
Additional information about how to change the refresh rate can be found on document CH000558.
Interference
A distorted image can be caused by magnetic or other types of interference. Verify no speakers, fans or other magnetic devices are close to the monitor.
Bad Monitor
If the above possibilities have been checked it is likely that the monitor is bad. To verify this it is recommended that the monitor be temporarily disconnected and then connected to another computer. This can be a friends computer, a work computer, and/or a computer at a service center. You can also help verify a defective monitor by connecting another monitor to your computer.
Note: Connecting your possibly defective monitor to another computer will in no way harm the other computer.
Good Luck/Please dont for get to Rate.Thank You.
SOURCE: HANNS-G MONITOR BLACK SCREEN JUST FLICKERS
I have the same problem. I leave the computer on for awhile to warm up the screen. I don't know why, that seems to help. I turn off the screen on the bottom right and do that a couple of times. Behind the screen I unplug and plug and unplug and plug the screen in again. After it gets going, it works all day. But at night I like to turn off the computer to rest. So I have to do this every morning.
SOURCE: Samsung 226bw visible flickers just after it is turned on
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
SOURCE: My flat screen Samsung monitor flickers on and off
or it could be the cable? if you have a different vga cable you can try that, if that's not the problem then it sounds like your lcd is possibly dying. you should also look at the pins on the vga connections and make sure none of them are bent
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
SOURCE: I have a Gateway HD Monitor Model 2100. The
Either you have a problem with the back light or inverter.
When you disconnect the unit from its signal connection, you should see no signal input message.
If the unit flickers and then go out, while disconnected, you can rule out the video card and assume it is the back lights or inverter.
90% of the time, it is the back lights.
