Tumble dryer working but generating no heat water just condensing in the drum area any quick fix answers please?
SOURCE: Beko DRCS68W not entering reset mode
If there is voltage on the thermostat but not going through even when the temperature is down it is possible that this could be defective. Now check using a multimeter to confirm the continuity on the thermostat and if the reset switch on this - if present - is off, if so press it down.
Now confirm the voltage from the control panel during the heating cycle and if voltage is outputted then it must flow. The connection must be checked on the heating element- trace to confirm.
