Hi
If you have forgotten your password to log on to windows then you will not be able to log on to your profile as this needs your windows password.
If you have a sepreate administration account on the laptop you can log on with this make another user account to log on, log on with this account to create your new profile then log off, back on as admin, you should then have access to the users folder and with admin rights you should have access to copy your stuff from the old user profile to the new one.
Cliff Cook
MCP
SOURCE: Dell Inspiron 1420 - says user profile cannot be loaded
Try this, it should work and it really is quite easy to follow -
1. Boot up in Safe Mode. To do this, hit the F8 key while the computer is
booting, and then scroll down to the "Safe Mode" option and press enter. On
my computer the user account icon appeared, but bigger than normal, and I
clicked it and it loaded my desktop in safe mode. It came up with an error
bubble saying that my user account hadn't loaded properly, but I just ignored
this.
2. Click the Start Button and in the white "Start Search" space at the
bottom type "regedit" (without the quotation marks). This will open the
registry editor.
3. In the left-hand pane, navigate by clicking the little triangles next to
the following folders:
HKEY_LOCAL_MACHINE
SOFTWARE
Microsoft
Windows NT
CurrentVersion
ProfileList
You should now have a list of folders all starting with S-1-5- and then a
number.
(You might need to drag the divider between the 2 panes of the window across
so you can read the whole folder name)
Look at the end of each name and you should see one with .bak at the end of
it, and there will be another one above it with exactly the same name but
without .bak at the end.
The one that's got .bak at the end is your old User Profile that Vista has
now made into a backup, and the one without .bak after it is the new empty
User Profile that Vista has created.
Just to check that this is the case, have a look in the right-hand pane for
each of the 2 folders and look at what's written after "ProfileImagePath".
For the folder with .bak at the end it should say C:\Users\ and then your
usual User Account name, and for the one that doesn't have .bak at the end it
should say C:\Users\TEMP.
What you need to do now is to rename the folders in the left-hand pane so
that the one with .bak at the end changes back to being the one containing
your proper User Profile and the new one without .bak at the end becomes the
backup. Do do this follow the next step:
4. Right click on the folder with .bak at the end and then click "rename",
and just change the ".bak" part to ".bk" - i.e. just remove the "a" from the
middle - (this is just to allow you to change the other one to have .bak at
the end). Press enter or click on some blank part of the screen for the
change to take effect.
Then, right click the one that doesn't have .bak at the end and click
"rename". Remove the .bak from the end and press enter or click anywhere on
some blank part of the screen to accept the change.
Then, right click on the one that now has .bk at the end, choose "rename"
and add the "a" back into the middle, so it now has .bak at the end. Press
enter or click on blank park of screen to accept the change.
Close the regedit window.
5. Click the Start Button and then "Restart".
It should work now, otherwise see link below -
http://support.microsoft.com/kb/947242
SOURCE: user profile can not be logged on. It says the
Kindly refer to site:
http://www.vistax64.com/tutorials/130095-user-profile-service-failed-logon-user-profile-cannot-loaded.html
SOURCE: Service user profile error
Boot into safe mode by spamming the "F8" button "after" you see your VAIO splash screen. You will be presented with a few options, select "safe mode".
When windows loads, you should now have access to your hidden Admin account. I have seen this account password protected and not protected, hit and miss. I would first try leaving the password field blank, then move onto passwords you know.
You can also remove the hard drive and install it into a desktop computer as a slave (extra storage). This will gain you access to all your files. If at anytime during this process you get error messages of "access denied", take "ownership" of the folder you are trying to open.
For the above step:
If your laptop's hard drive is not SATA, you will need a cheap converter to convert the hookup to one that will fit in a desktop. Below is a link to one so you know exactly what you are looking for.
http://www.newegg.com/Product/Product.aspx?Item=N82E16812203012
Hope this helps.
SOURCE: my acer when I log on says user profile service
use F8 and go into sfae mode, this will load a default profile and will allow you to add a new user (to create a new profile).
Then you can logon in using the new profile.
SOURCE: my Acer Aspire 5630 laptop
It seems that your profile got corrupt, simply login from the administrator account of your computer,
You can solve the issue by procedure below
go to my computer>users>your profile> and copy all of your required data including outlook data if you are using to external drive or other partition (e.g D Drive)
then delete the profile folder from your laptop from c:\users\your profile
restart your laptop and try to login again from your username/password, if it stills give the problem,
Login via administrator account, go to Start>run> and type
control userpasswords2 and press enter, here you will see your profile, simply delete your profile and restart again, when the computer boots up again it should show you your profile if not again login via administrator account and recreate your profile and restart your laptop
after you login to your account, simply copy your data back to its location
if you require more assistance feel free to reply to this post
Regards,
Bilal
