It depends somewhat on your OS and the software installed you have installed. With a Automatic Document Feed, the pages need to be face up and the top edge forward in the feeder. On the glass platen, put the documents face down.
Open a TWAIN-compliant scanning application (XP, Vista and Win7 all have Paint which can acquire scans). Vista and Win7 also have Windows Fax and Scan. If you installed other software (such as that which came with the scanner), you would use that - Epson Smart Panel or ArcSoft Photo Impressions. Next open Epson Scan (this doesn't work with the Mac software so look at epson.com for Mac info). This runs the scan (and any specific resolution adjustments you make). It will generally launch when you hit Scan in the application. You can run Epson Scan alone if you do not want to edit the documents right away. Click Start > All Programs > Epson Scan > Epson Scan to use Epson Scan. In the Epson Smart Panel, you would click Scan and Save to start scanning or Scan with Options to adjust the settings prior to scanning.
If the Epson Smart Panel is installed and set up for it (including having a monitor running), you can also initiate scans from the scan button on the unit. Scan problems most often occur when there is a block in two-way communication. Try a new data cable and a different port. If you have a USB hub or print server, try a direct connection. The cable should be under 6' long for best results.
They are no longer offering OCR for free you have to buy it seperatly if you want to use it, textbridge classic has it for $40.00 and it is useable with PDF and word and doc and docx's format.
Epson has software called "Epson smart panel" and you can select scan from the list of operations.
Turn your scanner on, (windows OS) click on "start" then click on "all programs", look for epson smart panel in programs list, click and let panel load, then select scan.
It will take some time for the scanner to warm and scan, so be patient, after it is scanned your options are to print, or save. If you save, be sure you know where its filed or "tell" it where to save, I recommend creating a new folder before in "your pictures" titled "scans" . Usually after you do this, it will save it there by default.
After working with Epson to unistall, re-install, and reset
everything the red light still comes on. Epson, and confirmed by
a repair dealer, said the light bulb on the scanner is bad. The dealer
said it is cheaper to buy a new scanner. My unit still prints in
b&w and color.
1. Make sure the shipping lock on the scanner is free see- set up sheet.
2. Remove all Epson software relating to this
device.
3. ReBoot.
4. make sure you are off line.
5. Fully disable any Anti Virus software
Switch off the unit and disconnect the USB cord
7. Now install the software and follow the
EPSON steps exactly -take no shortcuts
