Toilet is about 5 years old. tried to clean with Clorox, CLR, cannot remove stain. and stain keeps spreading.
Try using one of these A product called Kaboom Bowel Blaster and let it sit in the bowl for a while, then brush clean. This worked for me when others failed. You can try muriatic acid as a toilet bowl cleaner.Again let it sit for a while then brush and flush available from places like Home depot.Sometimes the toilets are not glazed as well as they should be you might call it a defect I call it poor quality control.
SOURCE: water line stain
Try a product called Iron Out. You can use it for a lot of different types of stains that build up in toilets, dishwashers, washing machines, etc. You can get it at any hardware store. I'm in PA, though, so I don't know if it's available in all states. This worked for me, but the minerals in your water may be different than mine and it may not work the same for you. Good luck!
SOURCE: We have a Jacuzzi X532 toilet. Can't get the water
I am not familiar with the model of toilet that you have, but many toilets suffer the same problem. It is usually due to the toilet cistern over-filling, as the water running into the bowl is the safety-overflow mechanism. The overfilling can be for a few reasons. The most common is that the fill valve is being held open, either due to mal-adjustment, or due to it being postioned slightly wrongly so that it hits either the side of the cistern or another part of the mechanism and can't close off properly. If you lift off the top of the cistern and watch what happens when the flush goes, you might be able to spot what is preventing the valve from shutting off entirely, and solve it. Hope this helps! :)
