Does anyone know what battery size goes in a diesel dz-4033 please?
SOURCE: instruction manual required for diesel watch DZ 7033
i have found the solution by visiting this site
http://store.dieseltimeframes.com/text/content/diesel/DieselENGLISH.pdf
All diesel watches manual instructions or (guide)
jamil soomro
toronto
SOURCE: Diesel dz 7081 watch screwposts - replacement?
The only place that is likely to have a replacement or be able to find you one is a watch repair shop, since such small parts are generally only found on watches.
SOURCE: Instruction Manual for DZ-7087
hey..i found out how to set the time for the model: diesel dz7087..
all u have to do is press and hold the light button..the when it starts ticking press the mode button repeatedly to set the time,date,etc...when u finished setting everything press the light button and everything will be set..
ciao ciao
SOURCE: my diesel watch gets reset everyday dz-7044110703
I have the exact same problem. The watch was working fine up until I had the battery replaced. I went to another watch repair shop (couldn't go to the same one as I had moved to another town) and the chap there explained that with Diesel watches, when the batteries are replaced a small button inside the mechanism must be pressed to reset the settings, if this isn't done then the annoying problem, inflicting our watches, will occur.
My watch worked fine after, for a few days, then it began to reset again; casting doubt on the watch repair man's explanation. I'll go back to see the chap when I have the time, prob next week and keep you chaps posted on anything new.
