Toilet is about 5 years old. stain keeps spreading an getting larger. Tried to clean with Clorox, clr. Nothing work Could this be a defect in the product?
Probably a mineral buildup. Pour a bucket of water into the bowl so that the bowl flushes but does not refill with water. In other words you want as little water in the bowl as possible so it wont dilute the cleaner. Use an acid cleaner like lime away in the bowl. Let it set for several hours or over night,. then scrub with toilet brush. Lime away is fairly safe but try not to splash it on your clothes or yourself. Wash it away if you do.
You may have to repeat to finish the job.
SOURCE: TOTO toilet with defective enamal
you could to try to sand off rough spots and re spray enamel there are companeys that redo tub's you could look it to one of them to redo toilet
SOURCE: "Can you replace only the toilet bowl and use the existing tank"
Its usually better to buy the set, but if you don't want too that's fine. As long as the water capacity of your old tank is what the new bowl requires. If you look at the set at the store, it will usually tell you the water capacity and specs of the new bowl. Although most bowls use the same holes and bolts to combine the tank and bowl, make sure the old tank will fit on the new bowl you selected.
SOURCE: flapper will not go down
Troy, the flapper otherwise known as the flush valve is easily replaced. They are also very inexpensive. Sometimes they can become distorted due to the clorine in the water and won't operate in the same way they did when it was new. I bet this will fix your issue and save you money as well.
SOURCE: Toto toilet Power Gravity intermittently running
You need to either bend the arm that connects tot he float down (if it is the type with the ball float) or adjust the height of the fill valve assembly. THis accomplished by slightly twisting the valve assembly carefully and sliding down a half of an inch or so and then twisting back to lock it in place.
This should fix you up right.
SOURCE: American Standard Hamilton Toilet Leaking
You have installed the parts improperly. You must have 3/8 of an inch slack in the chain from the flapper to the handle when flapper is closed.
