The head was running fine. Removed spool to rethread and now motor is running but head will not spin. Have reseated head numerous times as in past. Is there a reset button?
SOURCE: Black & Decker gh1000 trimmer head not spinning
The same thing happened to me. You either have a ruined belt pulley, or, hopefully, the belt burned out. Belts are easy to find online, but the housing is tricky to remove - see other posts.
I finally got it the plastic housing apart on my trimmer (there is one screw hidden under the label), only to find a total meltdown. The plastic pulley is ruined, and the only way to get it replaced is to buy a new motor (the most expensive part).
If your trimmer is no longer under warranty, then you can get a refurbished gh1000 for the price a new motor unit.
SOURCE: need the manual for the black & DECKER GRASSHOGXP
Click on: Instruction Manual....Print DOC
http://servicenet.blackanddecker.com/Products/Detail?isId=true&productNumber=GH1000&selectedType=16880#
